Question about Gamehouse Tap a Jam
Tap a jam has stopped working - Gamehouse Tap a Jam
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
2000 ford heater not blowing hot air,a/c work fine
The heater tap on the heater radiator is not working Most are vacuum operated through a cable . Check for tap operation or if the tap itself has corroded and jammed
Jan 12, 2013 | Cars & Trucks
It won't run it keeps saying it has stopped working
What oprateing system are you useing is your drivers up to date?
Jun 04, 2011 | Gamehouse Tap a Jam
Stopwatch second hand stops/jams at 57 seconds point, jamming the whole works. watch stops. keeps excellent time otherwise if stopwatch not used. 2003 SS model. bought new from rolex.
this watch will need a service from a rolex trained repairer wich wont be cheap 700 dollars min or 500uk pounds min..you could try tapping watch in palm of hand to see if a batton or luminous paint has come loose,then all it needs is movement taking out and blown clean inside case.any decent repairer can do this.sometimes the teeth on a wheel can wear in one place hence it always stops in same place.recomend service as best action,you never loose on a rolex...
Mar 26, 2010 | Rolex Daytona 116520 Wrist Watch
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
Water valve jammed
hi it sounds as though its stuck due to verdigris & scale, a common problem.if you break it all thats likely to happen is the spindle will shear off, which will mean a new one anyway. If you dont want to do this I suggest you turn off the water to the storage tank & open the cold taps till the water stops you can then replace the washer.whilstthe water is drained i suggest a new valve to be fitted for future servicing etc, also it might pay you to fit a service valve on the supply to the tap.
Dec 14, 2008 | Home
No air to the feet on my Mercedes C320-2003
a ha... the motor which control the flap is machanically jam or the motor is malfunction..
u can heard tap tap tap tap tap sound once u on ur car... after few minutes the sound will dissapear...
try to open the cover and check if the motor is function properly or machanically jamed..
Nov 19, 2008 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Paper Jam
I have he same machine. I found the solution elsewhere on this site for another Brother Copier.
Lift the ADF lid locate the little black plastic 'switch', slightly recessed in the fourth slot from the back of the printer, gently tap this swith so it moves, I tried forwards then back, close lid, press Stop/Exit.
Ding Dong! - Works a treat.
Oct 05, 2008 | Brother MFC-465CN InkJet Printer
Paper jam
It is very touchy. If the paper is in too far, you get the paper jam message, if you don't put the paper far enough down, you get the paper empty message. Try installing about 5 sheets at a time and after aligning them into the slot, lightly tap the 5 with the palm of you hand untill you feel the first stop. The second stop will be to far. Try putting it in too far so that you can get the feel for both stops.
Apr 12, 2008 | Lexmark P315 InkJet Photo Printer
Video Game Consoles & Games Logo
90 people viewed this question
Top Gamehouse Video Game Consoles & Games Experts
James Wishart
Are you a Gamehouse Video Game Console and Game Expert? Answer questions, earn points and help others
