Question about HP G60-230US Notebook
If num lock is off blank fields are field with ***********
When num key is off when the laptop is put on it fills the password with stars and even after loging at any time it starts filling blank areas fields with stars. this happens even when I use usb key board in instead of laptop key board
    New Friend:
  • 11 Answers
I had this problem and had to remove a virus. Try running your virus software or updating your virus/malware software.
Posted on Jan 25, 2013
2 Suggested Answers
  • 34 Answers
SOURCE: Letters keep typing even without keyboard
I'd try wiping and reinstalling the operating system or booting from a linux live-cd first to see if it's a windows issue or hardware issue. In the end though, yes I believe the motherboard is probably faulty.
Posted on Jan 23, 2010
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
I did everything they asked it keeps coming up saying all fields required but i filled in fields
For every incomplete fields that you made the error should be saying it or highlighting it with red colors. Just read it carefully. Make sure you correctly entered Word Verification: field. and don't forget everything you see field required make sure to reenter the password fields as it might become blank again.
Sep 10, 2011 | YouTube Computers & Internet
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
I have a satellite a200-1vp, at the start up it ask me for the hdd1 password, i did set this by myself by mistake, I do have the password so i can still go straight into the computer, but would like to...
You'll have to go in to the BIOS setup, this can be done by turning on you notebook and then press the key to enter the BIOS setup, see this website for the right key:
http://michaelstevenstech.com/bios_manufacturer.htm
You'll first have to enter the old password then leave the new password field blank, leave the the field to confirm also blank, this will disable the hdd password.
Aug 18, 2010 | Computers & Internet
I purchased a Motorola KRZR2 from Ebay, and although it works great, it cannot connect to the AT&T web. AT&T told me that since I didn't buy it from them, they will not help me out. What are my...
Your WAP and MMS need to be set up.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://home
Service Type 1: WAP
Gateway IP 1: 10.250.250.250
Port 1: 9201
Domain 1: <leave this blank>
Service Type 2: WAP
Gateway IP 2: 000.000.000.000
Port 2: 8080
Domain 2: <leave this blank>
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 5 minutes
CSD No. 1: <leave this blank>
User Name 1: <leave this blank>
Password 1: <leave this blank>
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: <leave this blank>
User Name 2: <leave this blank>
Password 2: <leave this blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name: <leave this blank>
Password: <leave this blank>
Click Done
Click Menu
Select "Set Default"
Then...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Jan 14, 2010 | Motorola Mobility KRZR K1 Cellular Phone
How do i get my gprs working
AT&T:
Main Menu
* Entertainment
* Services
* Data Account
* GPRS
- Find one free account (like Account 8, etc)
* Edit
- Change 'Account Name' and put the value 'ATT MMS'
- In 'apn' field put the value APN (which is wap.cingular)
- Fill the fields username and password with the ones on the table USER and PASSWORD (you don't actually need a user name and password for AT&T, you can leave these blank)
-Click 'Done' and say Yes to Save.
* Main Menu
* PIM
* Messages
* MMS
* Message Settings
* Server Profile
- Find one free account (like Profile 8, etc)
* Edit Profile
- Rename Profile and put the value 'ATT MMS'
- In Homepage field put the value HOMEPAGE (which is http://mmsc.cingular.com)
- In 'Data Account' select GPRS and then the account created before (the MMS one).
- Select 'Connection Type', choose HTTP and click OK
- Fill in the fields Proxy Address with PROXY and Proxy Port with PORT. Then click OK (066.209.011.061 is the proxy and 9201 is the port number)
- Fill the fields username and password with the ones on the table USER and PASSWORD (don't need a user name and password)
* Go back and Activate Profile
Nov 16, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Dont know what it is
Turn off smart password entry
You can turn off smart password entry to reduce the chance that someone might guess your BlackBerry® device password or smart card
password based on the smart password filter that your device applies to password fields.
1. In the device options, click Security Options.
214
2. Click General Settings.
3. Set the Smart Password Entry field to Disabled.
4. Press the Menu key.
5. Click Save.
For your information .........
If you use two-factor authentication and your BlackBerry® device password or smart card password is numeric, you might be able to use
smart password entry in some password fields. When smart password entry is turned on, your device is designed to remember the format
of a password that you type in a password field. When you type the password again, your device applies a smart password filter to the
password field. If the password is numeric, a 123 indicator appears beside the password field and you do not have to press the Alt key to
type numbers. If the password is alphanumeric, an ABC indicator appears beside the password field.
Smart password entry prerequisites
• Verify that the correct smart card driver and smart card reader driver are installed on your BlackBerry® device.
• Verify that two-factor authentication is turned on
Jun 04, 2008 | RIM BlackBerry Pearl 8100
HP G60-230US Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
