Question about Mitsubishi Televison & Video
My MITSUBISHI video cassette recorder HS-M60V(B) ejects the cassette
When a cassette is inserted it is ejected without starting to play
5 Suggested Answers
SOURCE: My Mitsubishi VCR HS-M60V rejects cassette tape
Take it to a technician
Posted on Aug 28, 2009
alltechserv.
  • 32 Answers
SOURCE: A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Posted on Sep 22, 2009
  • 4234 Answers
SOURCE: Inserted cassette doesn't play and immediately ejects
There are a number of "checks' made during the loading process to insure that the tape is not damaged should the VCR have a problem. If any of the checks fail, the cassette will be ejected as you describe. Since there are many possibilities for this behavior, I can not state for sure how to resolve this problem. These units are usually quite reliable and are probably worth a repair estimate. Take this in and get a detailed repair estimate. Armed with that diagnosis, we should be able to walk you through the actual repair.
Dan
Posted on Mar 04, 2010
Grubhead
  • 5397 Answers
SOURCE: I have a VCR Panasonic NV - FJ623 and when I
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Posted on Oct 30, 2011
Mitsubishi hs-u62 vcr cassette will not eject
Needz fresh belts. You can order common o-ringz uv the same length that will work fine, but usually not az long.
Apr 19, 2015 | Mitsubishi Televison & Video
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Mitsubishi VCR Model HS-821V Ejects Video Cassette & gives an error code E4
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
Nov 26, 2012 | Televison & Video
Sep 22, 2009 | Televison & Video
MX2, it displays the following: "remove the cassette" or eject. I thought it was a condensation problem but all attempts failed, please help me.
On Canon camcorders, "remove the tape" error is due to no data reading by video head. You may have clogged heads or somewhere along the area. Initially, I would try to insert good clean "video head cleaning tape" and run for about 7 seconds and see if that resolve the symptom. If it persists, it need a help from a technician. Good Luck. For further help, go to www.camerarepairjapan.com James
Feb 26, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
My ZR30mc video recorder will not eject cassette
Take the side panel off to see whether the tape is damaged and will not retreat into the cassette ( this will prevent ejection ). Remove old damaged cassette and insert new one. If the unit chews the new cassette camera should go in for VTR service.
Sep 01, 2007 | Canon ZR30MC Mini DV Digital Camcorder
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
