SOURCE: Car stereo removal
any good car stero shop in your area will do it for free!! (on the hopes you will come back later to purchase from them.
you may try a thin (pointed) wire coathanger on each side, it is simply a hook at the end that needs to be dis-lodged.
Thanks for using FixYa - a FixYa rating is appreciated for answering your question.
SOURCE: Sony XR-C350 - cassettes get rejected
Hi I do not have a solution but my XR-C350 is having the exact same problem. I just had some repair work done on the car and the baterry had to come out. I have not reset the the system so I might try that? Any help would be greatly appreciated
Tony
SOURCE: The face plate for my
Hello
You haven't mentioned nothing about its other functions. Does it loads CD, plays it and so one. Only mentioned about its back face plate backlights only. If this is the only trouble, that is, the backlight only not lights up, it can be repaired. Not even back light, most of the faults can be repaired. Backlight is produced by lighting up LED [Light Emitting Diode]. It may fail as if a bulb fails. It can be replaced. If problem is not this much, and more, inform me by Fixya. OK.
