Question about Edirol R-09 Digital Voice Recorder
My edirol r09hr intermittently wont switch on
I use my edirol r09hr most days. Its about 4 years old. Over the last few weeks, it often does not switch on at all, or takes a lengthy press on the right hand side button to switch it on. I need to resolve the problem urgently as I use it for my self employed work. Is there anywhere in the uk that repairs r09hrs? Any help greatly appreciated!
2 Suggested Answers
SOURCE: R-09 broken, don't know where I can repair one fast in UK
Hi Igor,
You have probably long since either had your Edirol repaired or found a replacement. If the latter situation is the case, and you have your R-09 sitting around collecting dust, I might be able to help. The buttons likely did not fall off, but were pushed back into the unit. Try opening it up by unscrewing it from the bottom (First open the battery cap) and carefully opening it up. You'll lkely find the buttons pushed back into it.
I learned this after a friend dropped mine at my wedding. Determined, I set out to fix it.
Good luck to you or anyone else reading this post,
Peter II
Posted on Jul 12, 2010
Whirlpool gas oven light bulb lasted 5 years but now keeps burning out?
all appliance bulbs are not created equal it needs to be specifically an oven bulb to take the heat .
Feb 14, 2016 | Whirlpool Accubake 30" Self-cleaning...
Our refrigerator started not being cold
your rtc or contactor on the compressor body needs replacement
Jan 01, 2010 | Maytag Performa PAV2200
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Gets stuck in defrost cycle, new thermostat already fitted
If you would like to stop the defrost timer from intermittently causing this, the defrost timer will need to be replaced. It's a simple part to replace and not expensive. Thanks, Sea Breeeze
Apr 27, 2009 | Refrigerators
Not getting any power in my 3-year-old Sennheiser MKE44P even with a fresh battery inserted.
Battery acid is very corrosive and if you have had a leakage then the acid could have gotten further up into the mic and corroded some of the components, most likely a small power lead from the contact. It is always worth taking the battery out after use, a £3 battery can ruin £300 worth of kit.
Oct 17, 2008 | Audio Players & Recorders
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Mar 05, 2008 | GE JVM2050 Microwave Oven
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
Edirol UA-101
DOWNLOAD THE LATEST EDIROL DRIVERS AND INSTALL ...
Aug 19, 2006 | Edirol UA-101 External Sound System
Edirol R-09 Digital Voice Recorder Logo
57 people viewed this question
Top Edirol Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Edirol Audio Player and Recorder Expert? Answer questions, earn points and help others
