Question about Linksys Wireless-G Broadband Router
Tried to attach a Linksys Wireless G router - no internet now
Tried to attach a Linksys Wireless G router - no internet now...when I plug the internet cable back into the computer, the internet is fine...when I try to use the router, I get nothing
  • mickey_curtr Feb 08, 2009
    was using wireless-g and it just stopped....replaced with new, connected, and located access point but will not connect to internet.
  • honey0786 May 11, 2010
    I just want to clarify when u plug the internet cable back into the computer, the internet is fine, r u using modem there, if so then router need to be configured, if u r using Linksys Wireless G router with wired but u need a wireless connection using router, can u confirm which os ?
  • 27 Answers
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
Where do i put hinternet connection cord at?
1. Go to Best Buy. Get a Linksys wireless router. Hook up your internet to the slot in the back that says INTERNET. Then attach an internet wire into slot 1. Plug the other end into your computer. Repeat with any other computers. Put the CD in any computer hooked up with the Linksys. Set it so wireless connections are allowed and set a password. Use the internet channel, wait until your Linksys pops up, and enter you password. You're good to go.
Note: I was talking about this Linksys: http://www.linksysbycisco.com/US/en/supp...
2. Get a $40 Wi-Fi adapter and hook it up to your computer (assuming it has internet). After setup, You will have Wi-Fi, but it has a tiny range. I recommend the router. The router has a MUCH larger range and costs $20-$120 depending on how fast and how large of a range you want. Any router will work as long as it's wireless.
Feb 26, 2011 | Nintendo Dsi Pink Console
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
I cannot connect wirelessly to my router from my lap top
Check this link
http://fixhomenetwork.com/blog/linksys-e1000-e2000-e2100l-e3000-router-setup/
Set up a Linksys Wireless Router
  • 1 Choose and purchase a Linksys router, taking into account your budget and computing habits.
  • 2 Attach the antennas to the Linksys wireless router.
  • 3 Place the router in a central location, making sure it's not surrounded by metal. (A signal can't be obtained through metal.) The router should be located so that the distance between clients (computers) is somewhat equal. This will create a better connection.
  • 4 Plug the Ethernet cable into the "Internet" port on the back of the Linksys router.
  • 5 Connect a computer to the router by plugging another Ethernet cable into the Ethernet port on your computer and attaching the other end to one of the available ports on the back of the router. You can choose any port except the one labeled "WAN."
  • 6 Plug the router into an electrical outlet.
  • 7 Wait for the power light to stop flashing, at which time the router is finished booting up. While the router is booting, the power light will be blinking. This process may take a few minutes to complete.
  • 8 Reboot your computer so it can access a new IP address from the router through the Dynamic Host Configuration Protocol (DHCP).
  • Configure the Router
  • 1 Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
  • 2 Use "Admin" as the username in the pop-up box and leave the password blank.
  • 3 Connect to the Internet and click on "Internet Setup."
  • 4 Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
  • 5 Set a service set identifier (SSID) to identify the router and change the password.
  • 6 Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
  • Sep 26, 2010 | Cisco Linksys E1000 WirelessN Broadband...
    Laptop cant connect to internet
    You will need to check the wireless settings of the router
    is there any computer connected to the router ?
    If yes then you can open the router set up page on that computer.
    Router set up page is the page where you can check all the wireless settings of the router.
    Click here for step by step instructions
    Apr 06, 2010 | Linksys Wireless-G Broadband Router
    After changing our att dsl service the main computer can access the internet but will not work with linksys router attached...so no wireless. How do I reconnect the router?
    turn off the modem turn off the router hook the internet on the modem to the router install cd and restart before restarting plug the router and the modem to the out let and restart pc
    Aug 05, 2009 | Linksys Wireless-G Broadband Router
    My linksys wrt54g v8 will not recognize the internet
    Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
    Gary
    Jan 24, 2009 | Linksys Wireless-G WRT54G Router
    Cannot access internet with a linksys router
    Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
    Jan 15, 2009 | Linksys Wireless-N WRT150N Router
    Linksys Wireless model # WRT54GS
    It sounds like the router went bad and your need to get a new one
    Mar 05, 2008 | Linksys Wireless-G WRT54GS Router...
    Linksys Wireless-G Broadband Router Logo
    78 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
