Question about Luxor Mobile Flat Panel TV Mount and Stand - Black
No signal today could it be the snow - Luxor Mobile Flat Panel TV Mount and Stand - Black
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Switch off at the mains for at least 1 minute and try again.
Posted on Jan 21, 2013
MTD Mastercraft Snow King Snowblower (1997) electric starter stopped operating today (during a snow storm of course). Any ideas? Thanks. Checked cord - good condition. Power to the chord. David
It was running and stopped while using or it worked one day but not the next?
The Machine stopped running or just the electric starter? If just starter check to see if snow/ice built up around starter button.
Jan 06, 2017 | Garden
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
How to boost my mifi 220 signal
Since your signal goes up and down, I would suggest buying a large ham radio antenna, about 15 foot, and mounting it on a seesaw. On one end put a large automotive spring, and on the other end put your antenna. Then attach a very long copper stereo wire from the ham antenna directly to the mifi unit.
When you signal starts to go up and down, you can counter it by going out and starting the seesaw. Once it hits the spring, it will go back up and then return and so on. Your signal will still go up and down, but the seesaw action will counter the up and down motion.
That should improve your signal and be steady year round unless you get a large snow storm and your seesaw is weighted down by lots of snow. In that case, you will need to shovel the snow periodically, but you will have your mifi signal back to normal.
Nov 25, 2012 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Tfdvd1591 - screen has snow. It was working fine and I changed channels too high I think. the lcs settings has a channel number and I am not sure what that should be
This is actually a copy of the manual. When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components
Jan 16, 2011 | Coby Televison & Video
I have hooked up cable to the RF connector but it will not show a picture. I also tried an anntenna and it does not pick up a picture either. All I get is snow. However, I had a VCR/DVD combo connected and...
This tv is analog tv,will not get today free air tv broadcasting signal.Today free air tv signal are all digital free air broadcasting tv signal now.Anolog tv must have a pay cables tv or satalites tv signals to get a picture on analog tv set.U want analog tv to get the free air digital tv broscasting signal.The analog tv,must have it broadcasting tv signal must go through a box call a Converter box to able to produced a Digital free air broadcasting signal for analog tv to get a digital broadcasting tv signal.
Nov 07, 2010 | RCA F27442 27" TV
Blue screen
it is not seeing a signal source.in the earlier days,"snow" would be evident but today the tuner signal lost results in a blue screen.check the cable signals and the cable box.
i would put cable from the wall directly into the set and see if there is a picture,and then check that it is not set to aux input with nothing connected
Aug 18, 2009 | Sansui DTV2760 27" TV
Abs light came on in my 2003 chevy venture
If there is snow and ice building up around the wheel speed sensors, yeh, that would make the light come on.
Jan 31, 2009 | 2002 Chevrolet Venture Passanger
Sanyo DS20930
The problem with saying my TV is acting up, is you did not mention the model #, type of TV, tube type, projection, plasma, LCD. They all have different faults that can cause this. The first thing you do is to hook up signal to your video inputs if you have any and see if the signal works that way, if so then you probly have a bad tuner, or you cable box is bad.
Oct 26, 2008 | Sanyo DS20930 20" TV
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Luxor Mobile Flat Panel TV Mount and Stand - Black Logo
22 people viewed this question
Top Luxor Televison & Video Experts
sureshd2008
gbob59
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
