Question about Garmin GPS III Plus GPS Receiver
Garmin GPS III plus- ROM failed message
I just pulled out my GArmin GPS, after years of not using it, and it says ROM failed. Any ideas? Its still seems to work ok. Also it wont work on batteries, just the cigarette adapter.
Try leaving it on for a few days on cig lighter with unit ON. gps III plus has a rechargeable valadium battery soldered to the board on the inside of the unit to hold memory of your waypoints.You can solder a new one in for about 5 buks-it may need a new one but try charging it first
Posted on Jul 23, 2009
GARMIN S1 GOLF GPS WATCH. I WOULD LIKE A LIST OF THE GOLF COURSES I CAN VISIT WITH MY GARMIN S1 WATCH. MY EMAIL: BRAEM.FRANCINE@SKYNET.BE THANK YOU
A list of the European golf courses for the Approach S1 Golf GPS watch can be found on Garmin's website.
http://www8.garmin.com/intosports/golfcourse.html
Sep 20, 2011 | Garmin GPS III Plus GPS Receiver
Have a garmin gps3 that will not power up - batteries checked OK. gps hasn't been used for a couple of years. replaced batteries with new - no go
IF it stil won't pwer up with the dc plug, I suspect the internal battery. Lots of info online on replacement, you can CAREFULLY snip one lead as a a diagnostic test to take it out of the circuit. Good Luck!
Sep 07, 2009 | Garmin GPS III
Bad white lines on the Garmin gps III Plus display..... how we can repair it?
It sounds like you have a problem with the screen itself. Garmin at http://www.garmin.com has an excellent repair program. They repair your out of warrant GPS for a flat fixed rate. The GPS is like new when you get it back. Just to to the Garmn web site click on the support tab and follow the menu selections from there.
Apr 05, 2009 | Garmin GPS III Plus GPS Receiver
How to reset the Garmin streetpilot III deluxe
DO NOT DO THE FOLLOWING unless you know why you are doing it. If you press and hold ROUTE when the unit is powered up, you do a master reset. This will clear all data and user variables. Unlike previous Garmin GPS receivers, this will NOT clear the temp compensation curves and non user data.
If the MENU key is pressed and held when the unit is turned ON, an undocumented test screen is activated which incidentally measures battery voltage, temperature and a few other things. Pressing QUIT (several times) from the test screen gives you a set of display test screens.
Mar 27, 2009 | Garmin Streetpilot III Deluxe GPS Receiver
How do I connect my garmin iii plus to my modern pc for downloads?
Looking for a way to connect a serial device to the USB port on your PC or Mac? Our USB High-Speed Serial Adapter provides a simple and reliable solution. This adapter is broadly recommended by serial device manufacturers due to its dependability and "Best in Class" compatibility.
http://www.tripplite.com/en/products/model.cfm?txtModelID=3914
$45.99
Mar 22, 2009 | Garmin GPS III Plus GPS Receiver
Broken screen on Garmin GPS III
A couple of ideas, craigslist, ebay, or a Garmin Dealer. They can actually purchase discontinued GPS for a considerably lower price.
Good Luck!
Jan 21, 2009 | Garmin GPS III
Garmin V
I think I may have found the solution.
A reply for a post on another site:
I visited the Garmin Corp office to seek help with that problem. If the shut down occurs right after satellite acquisition and the screen may show just a narrow black line going across it, it is likely due to some program changes the sattelite folks did without telling the software programmers. Garmin web site has a free download fix for the problem. Another option is to go into your settings and turn off the WAAS. Hope this helps. Go to the web site, check downloads, find your model gps and there you go. Good luck.
I disabled WAAS and so far so good.
I couldn't find the fix on the Garmin site.
HTH.
Oct 12, 2008 | Garmin GPS III
Garmin gps III / internal battery replacement
March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, that is, they simply clip into place. Replacement batteries can be purchased at less than a $1.00 of E-Bay.
Jul 07, 2008 | Garmin GPS
Bought StreetPilot III used, can't locate satellites
Are you using it outside or in your car? Mine will not pick up sats fron inside my house.
Yooper-Al
Jan 30, 2008 | Garmin StreetPilot i3 GPS Receiver
Garmin GPS III Plus GPS Receiver Logo
368 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
