Question about Samsung NC110 Netbook
OPERATION NOT FOUND - Samsung NC110 Netbook
  • Samsung Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing. The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd \ cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error. Hope this helps.
Posted on Jan 22, 2013
My notepad says operation not found
Does it say "operation not found", or "operating system not found"? Big difference...
Jan 21, 2013 | Samsung NC110 Netbook
Operation manual for emachine el1352-23e we need the operation for our machine if possible?
your manual can be found here
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=2080
Apr 15, 2011 | Computers & Internet
Will not boot into windows all of the time ' stops and says disk not found
operation system corrupted.
should repair/recover your operation system boot-up.
Dec 06, 2009 | Acer Aspire 5100-5033 Notebook
OPERATION SYSTEM NOT FOUND
You must of handled to motherboard incorrectly and possibly fried the SATA/PATA controller, usually found on the North or south bridge. My friend had the same problem, leaving the motherboard useless. IF this is a laptop your screwed (I.E. motherboard is junk). If this is a desktop you can either replace the motherboard OR you can buy a SATA/PATA card that inserts into the PCI/PCI-E slot to create a place to plug your hard drive in. Hope that helps.
Jun 04, 2009 | Fujitsu Siemens Computers & Internet
The Problem is when i turn on the laptop system operation not found is written on the screen.
More than likely, your hard disc is gone, or a virus has corrupted your Operating System.
Try inserting your Recovery CD into your drive, and then boot from that disk for a restore. You'll probably lose your files.
May 28, 2009 | Fujitsu LIFEBOOK E351 (FPC030171) PC...
Operation system not found
Do you have a system recovery disk or a windows Xp or what operating system you have disk, I need to know some things like what you did, How you lost your operating system, So we can find a way that hopefully you won't loose all your files.
Jan 04, 2008 | Sony VAIO F340 Notebook
HOW TO TURN ON OVEN
I found an Ad with a description of the burner knob operation. Unfortunately I found nothing on the oven knobs. However, it's possible that the oven knob operation is similar to the burner knobs... * Dual burner operates by pushing in knob once for inside ring only (1,000BTU) and pushing in again to activate the outer ring (total 16,000BTU) Hope that helps!
Jul 30, 2007 | DeLonghi DEFSGG36D-SS Gas Kitchen Range
CAN NOT TURN ON OVEN
Samsung NC110 Netbook Logo
48 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
