My epson me 340 ink blinks red light but there are plenty of ink in the cartridge
SOURCE: Ink & Paper blink red at the same time
I managed to solve the problem, thanks to this fantastic freeware tool: http://www.ssclg.com/epsone.shtml The problem has to do with the porous inkpads which are expected to overflow after a fixed number of nozzle cleaning cycles. However the problem is a software, not a hardware one. This great tool resets countes as well as ink cartridge chips. Thank you very much FixYa all the same for trying. Too bad there are some lunatics who post unrelated topics to this forum. Kind regards, PM
Posted on Sep 30, 2007
ohms
  • 1879 Answers
SOURCE: Epson Stylus C45 not printing
common issue, the printer will still shoot blanks even if you try another ink or do several head cleanings.
i got a lot of them with that problem, but since epson prints beautiful photos, i don't mind exchanges or getting a new one.
Posted on Feb 08, 2009
websnail
  • 419 Answers
SOURCE: epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Posted on Mar 09, 2009
SOURCE: EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Posted on Feb 12, 2010
SOURCE: epson rx520 E-01 fault
Hello someone help please, I recently bought Epsom SX215 from amazon when I switch on it's tells me to selcet language after that I get this message: ERROR E-01
I have no idea how fix this issue. Amrit
Posted on Mar 21, 2010
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Epson t60 two orange lights blinking
use this interactive guide to resolve the issue. They are considered red lites not orange. FYI
Epson Printer Error Lights INTERACTIVE Meaning of Red Blinking Leds
Dec 10, 2014 | Epson TM-T60 Printer
My epson me 340 ink absorber is full...please help!
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Jan 12, 2013 | Office Equipment & Supplies
I have an epson stylus tx115 multifunctional printer with the continuous printing system installed . there is plenty of ink in the printer . A red light is flashing telling that there is not ink , I...
You must reset the cartridges chip. About " there is plenty of ink in the printer " you mean ink leakeage in to printer ? If yes, first thing is to clean the printer ( the ciss is not instaled corectly) and reinstall the ciss. The ink tank of ciss should stay at the same level with the printer.
Dec 31, 2017 | Epson Stylus Photo R320 InkJet Printer
Epson R2400 paper and ink lights blinking red. Ink waste pad replaced and counter reset to 0. Lights still blinking red. Close inspection for any loose objects in printer but none found. Please advise....
Try to turn on your printer without the ink cartridges. When the printer starts and ask for the cartridges, put them back in.
(To remove the cartridges turn on the printer, watch the print head carriage move, when it is at the center quickly unplug the power cable, move the carriage by hand to a position where you can remove the cartridges, after removing the cartridges push the carriage to the right where it should be parked.)
Sep 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
R 340 cartridges have remaining ink but printer
just go to the process of ink cartridge replacement without actually putting in new ink cartridges, sometimes printers make read errors, just make sure ink cartridges are placed properly to position.
Jan 17, 2010 | Epson Stylus Photo R340 InkJet Printer
Red lights blinking
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Dec 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
My troublesome printer
New ink comes with a strip attached at the ink hole and sensor area, makes sure u ermaove them also try to clean the catridge contacts in the printer
Mar 06, 2008 | Epson Stylus C60 InkJet Printer
167 people viewed this question
k24674
jasbo
jasbo
