Question about Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834)
I'm trying to get my modem connected to the work group switch linksys. I can't get internet
  • 27 Answers
You might need a router instead of a switch.
what is the model number of the modem?
Posted on Feb 20, 2009
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
Dec 28, 2012 | Computers & Internet
WRT54GS ROUTER don't work with new modem
I would suggest you to look into the user manual first it may solve your problem.
Click HERE
Goodluck..
Feb 15, 2008 | Linksys Wireless-G WRT54GS Router...
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and...
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Jan 04, 2011 | Linksys SR224 (srw224) 2x1000 Mbps...
Linksys modem is being a pain in the *** cannot get internet
OK step at a time. Is the modem plugged into the correct place on the router. There should be 4 or 5 slots that are grouped together or appear separated from one particular slot on the router? Sounds to me like you are reaching the router but not getting internet access??? Does your laptop show being on a network with the Linksys? Make sure you have the router wired correctly. If you have time warner they have 24/7 phone tech support
Mar 05, 2010 | Linksys Wireless-G Broadband Router
Lost the internet connection on my laptop that worked before (Linksys wrt310n)
first check if you have internet with the modem if yes then you'll need to reconfigure the router. Contact router's manufacturer to assist you how to set it up.
Sep 14, 2009 | Linksys WRT300N Wireless Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My DSL was installed. I am trying to hook up my linksys wireless router, when I do the internet does not work. What am I doing wrong?
modem type ? make sure it is on modem-only mode if it is a home-gateway type.
connect modem ethernet to router internet port (located next to the power port).
press & hold for 10 secs. the routers reset switch (until all lights blink).
launch the internet connection wizard & select "computer is connected to a gateway / internet connection is always ON"
Jan 14, 2009 | Linksys Wireless-G Broadband Router
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys EtherFast 10/100 16-Port Workgroup Switch [ EZXS16W ] (104834) Logo
189 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
