Question about Sony VAIO PCG-GRT360ZG Notebook
When i start up my computer the screen blinks like it has a bad connection then it goes black
  • 142 Answers
The connection may have come loose or screen damaged, try booting in safe mode. if screen still does nothing you will have to check the above,
if screen works, the display settings may be too high.
Posted on Jan 27, 2009
ASUS EeePC 900A- black screen blinking cursor
The hard drive has issues, or the window files are corrupt. I suggest a computer repair store to retrieve files and test hardware.
Aug 05, 2012 | ASUS Eee PC 900 Notebook
Black Screen of DEATH
well try finding someone who repairs coumpters from their home it is alot cheaper. explain your problem they should tell you weather they can fix it
Jun 30, 2012 | IBM NetVista PC Desktop
My screen is black and sound is off. The green
I have the same problem. Can a bad lamp cause the sound to go out?
Jun 24, 2010 | Sony KDS-55A2020 55" Television
Monitor blinks the log on screen and then goes black
If possible you should try and connect the monitor to a different computer and see if you experience the same issue (or connect a different monitor to your computer and see if the same issue occurs). Sometimes the issue is with the graphics card not pushing the signal strength with enough power to keep the image on. If it is indeed the monitor that is bad, I would suggest buying a new one unless the monitor is still under warranty. You can get a decent size monitor from $150-300 and there are plenty of great deals out right now.
Nov 27, 2009 | Samsung 206BW Monitor
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
My Gateway monitor FPO 1975W is blinking?
Hi there, it sounds like this monitor is going out on you. Try a different monitor if you can, see if that fixes the problem!
Apr 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Sony VAIO PCG-GRT360ZG Notebook Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
