Question about Konica Minolta Minolta Di 650 Di 551 Di 5510 Di 7210 Copier Toner 604a
How to clear error code c-1450 on di551
A rat entered by back of machine. l tried to check the cables but seems to be good.tell me what can i do to rectify this problem.
  • Konica Minolta Expert
  • 337 Answers
C1450 Sequence timeout. Good luck with that
Posted on Jan 30, 2013
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
The error no. 0733 0000 is for whwt can u please tell me......
Error 733 is a communication error between the reader (scanner) and the DC controller board. This code usually occurs when the cable that joins these two units has come loose. Shut down the copier unplug the cables and re-attach them ensuring there are secure. Turning the machine back on should clear this problem up. Should this not clear the issue, seek a Canon trained tech to trouble shoot controller board. Good Luck
Jun 22, 2011 | Office Equipment & Supplies
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 27, 2009 | Toshiba e-Studio163 Copier
Have a ricoh aficio 450 and there is error code sc 623?
1. With the machine turned off. Go to the back of the machine and disconnect the cable that goes to the paper deck.
2. Turn on machine.
3. Turn off machine.
4. Reconnect the cable.
5. Turn on machine.
6. If problem continues you need the BICU
Dec 17, 2008 | Ricoh Aficio 450 Copier
I have an error code coming up E32. I have pressed the clear button but it is not clearing. I can not enter anything under any department.
Hi Skitso,
The problem is listed as afax machine error but the error code quoted seems more to be that of an error on a cash register.
If this is correct and it is a Sharp cash register the error is telling you that you need to enter your clerk or cashier ID.
For ease of reply try pressing the "1" and then the CLERK ID key.
Regards
Gavin.
Oct 08, 2008 | Sharp Office Equipment & Supplies
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
press the #2 and #8 at the same time (simultaneousley)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
Jan 25, 2008 | Ricoh Aficio AP3800C Laser Printer
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Konica Minolta Minolta Di 650 Di 551 Di 5510 Di 7210 Copier Toner 604a Logo
177 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
