Question about Roper RUD5000H Dishwasher
I have a bosch dishwasher mod. SHU43. It will not drain. I have checked the drain hose for obstruction. ?????????????????
  • 10,865 Answers
Remove the cover below the door and carefully look inside. You will see that the drain hose is connected to a small pump. That pump may have an obstruction in it such as a little piece of glass. Unscrew it from the frame so you can check it carefully. good luck.
If there is no obstruction the pump may not be turning on. To check that you will have to run the dishwasher and listen for the pump to come on. If it doesnt come on you will have to replace it.
Posted on Jan 27, 2009
My Bosch dishwasher keeps back filling from the sink or garburator.. Is there a p-trap in it?
there is a p - trap sort of, your drain hose is meant to work as one, when properly installed the hose will have a hole drilled for it to come ththat is slightly higher than the drain of the sink
Jun 22, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
THE WATER WILL NOT DRAIN OUT
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The water is not draining from the bottom of the dishwasher
Kevin
Dec 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water wont drain, I have removed drain hose from back of machine run cycle and still nothing more than a trickle. I am guessing its plugged but im not sure of the best way to test or clear the plug. its a...
im a old bosch tech and your problemis in the drain pump. remove 1 screw in the bottom of the unit and you will take off the plastic door, spin propeller and remove obstruction that will do it. if this helps send me a 4 thumbs up post thanks
Feb 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishawasher won't drain, sounds like a stuck garbage disposal
check for a kink in the discharge hose. Also, the hose must go up higher than the top of the dishwasher, then descend to the drain. Otherwise the waste water will flow back into the tub by siphon action.
Jul 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHX46L05UC Dishwasher
You cannot access the drain hose "internally" you will need to pull out the dishwasher and probably on the left side if facing underneath the drain hose will be connected with a screw clamp most likely.
Feb 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Roper RUD5000H Dishwasher Logo
70 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
