Question about Broan-NuTone Allure® I WS136BC Kitchen Hood
Fan Grill is discoloured
Tried to wash the grease off one of the fan grills and being unsuccessful with many attempts using different methods, finally tried diluted bleach but it discoloured the metal. I think I have to replace that fan grill but I don't know how to go about ordering it.
  • 1 more comment
  • patata Jan 27, 2009
    Where can I find nappi-sand?
  • patata Jan 28, 2009
    Thank you for clarifying...I will try this!
  • 142 Answers
Try contacting the manufacturer, or the supplier via heir website, or local repair agent. i use nappi-sand, and soak overnight, if their discolored, the naip-sand or like restores them.
Posted on Jan 27, 2009
  • shyspeed Jan 27, 2009
    sorry im in australia, a detergent with oxygen action, we use it here to get things whiter, like omo active etc.
Freezer is freezing, but ice box is not cold. Told to clean fan. Where is the fan located?
Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.
Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.
Reinstall the pan and the grill.
Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.
If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.
If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.
Feb 25, 2011 | Refrigerators
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Stoves efa700h grill cuts out after around 20 mins, the grill gets very hot, read a cpl of posts about fans and thermo cut outs, easy job? appreciate any help
On the 720 there are two thermal cut outs. Looking at the wiring diagram, the cooling fan and the clock are the only two items that will run independant of the cut outs. So, is the cooling fan running ok or not? If it is and the grill is cutting out, then it could be the thermal cut out that has aged - or the fan may be running slowly because of age or there is a build up of dirt grease under and around the oven and on the outlets that stop air curculating properly.
If the fan isn't running then you need to replace it or the fan timer PCB may have failed. Once you have gotten into the oven's inards, you can test the fan to see if it runs or not.
Nov 16, 2010 | Stoves 720EF Electric Double Oven
Fan works but oven doesn't heat
Check at the terminals and look for burned wiring
Sep 24, 2009 | Ovens
Ignites, but flashes, will not burn steadily
It sounds like grease has dropped down and clog your burner unit. It should be cleaned and then the flames should be even once again. You would need to use a degreaser to clean the burner unit which is located at the bottom base.
Jun 04, 2009 | Tec Patio II Grill
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
Ignis Oven functions
Definately the control with 2 lines where the fan kicks in. The grill and oven elements will come on. The fan will disperse the heat from the grill element evenly and more quickly inside the oven. You will need to reduce cooking temperatures by about ten percent though,or youll burn your dinner. Also keep food down ,not too close to grill element at top of oven, middle is fine. Hope this helps. Regards..
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No heat?
hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
Feb 29, 2008 | Bosch HBN 131560B / 131520 hot-air...
Broan-NuTone Allure® I WS136BC Kitchen Hood Logo
116 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
