Question about Refrigerators
Inside of freezer door bubbled up
We had a burst pipe last week and the fridge freezer was sat in water for a number of hours then it had to be moved so the floor could be taken up, since the a few large bubbles have developed on the inside of the freezer door and it also appears to be noisier. the bubbles seem frozen and cannot be pushed back in. any ideas why this has happened?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
If the pipe that burst was spraying water onto the refrigerator, it is likely that some water got between the inner panels of the freezer door. This water then froze and expanded, pushing out the inner panel of the freezer.
Posted on Jan 21, 2013
  • 3 more comments
  • hannah jackson Jan 21, 2013
    the burst pipe wasn't near the freezer but it was stood in over an inch of water.
  • Vince Pilgreen Jan 21, 2013
    Is the freezer on the bottom of this unit?
    yes it is
    and the bubbles appeared after the leak...surely can't be coincidence?!
    It sounds like water got behind the panels and froze, expanding and pushing out the panels. If the water was deep enough to get behind the panels and the inuslation between the inner and outer panels wicked the water upwards then I can see how it could happen. The way you describe it, it sounds like solid ice behind the bulging areas and the only way that can happen is if water gets in there.
SOURCE: Beko frost free fridge freezer,
sounds similar to mine. Find the source of the bubbling noise (defrost timer at the bottom), remove the cap and advance the timer with a screwdriver. If you fridge starts working, your defrost timer is faulty.
Posted on Jul 28, 2008
  • 29 Answers
SOURCE: Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Posted on Aug 13, 2008
rablack66
  • 48 Answers
SOURCE: Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Posted on Nov 13, 2009
Testimonial: "Many thanks for your help. The drain was blocked with ice as you suggested. "
iwillfixforu
  • 619 Answers
SOURCE: Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
kel1guy2002
  • 3740 Answers
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Posted on Mar 27, 2010
Frigidaire F45ZR24J 2 Door-Inside of Fridge has gone warm and Freezer side is also starting
first check if there are cooling coils underneath. They might use a good vacuum.
Next check the setting to see if it got moved and move it to cooler setting.
Look at door seals to see if there are any gaps where you could slide a piece of paper past.
last would be the freon might have leaked out. This repair is tricky
because you need to check where the leak is. Soapy water would make bubbles if there is a leak.
good luck!!!
Mar 27, 2013 | Frigidaire Refrigerators
I bought a whirlpool fridge freezer last two weeks it was working fine but i noticed that the freezer is making too much ice when i set it at temperature 7 which is melting and i keep seeing water under...
Water under it is fine as long as it is not on the floor. It should be in a pan that came with the unit. You should have 2 temp setting for the unit..1 for the freezer and one for the frid. set the freezer for 5 to start. and then set the frig at 5. and adjust only the fridg side after a few hours. If this does not wrok call the place you bought it from as it may have a bad swthch on the indoor fan or a bad flapper door that allows cold air from the freezer to cool the fridg. But you have to start at mid range and adjust only the fridge side moving it up or down buy 1 number at a tiem.. Let me know know. I hope this helps Jon
Aug 13, 2011 | Whirlpool Heating & Cooling
Last week our electricity was down for some time. Then Ice from freezer fall down from and fridge stop cooling
Hi
These units rely on air being transferred from the freezer to the fridge, so to make sure that the air ways are clear follow the steps below.
1. Empty the fridge and freezer and store the food elsewhere.
2. Switch off and unplug the unit and leave for 24 to 36 hours with the doors held slightly open. You may get quite a lot of water on the floor, you just need to mop it up, this is normal.
3. Wipe out the inside of both sides to leave them clean and dry.
4. Plug in and switch on, wait around 4 hours.
5. Re stock the unit it should be OK.
If there is still a problem please come back to me
Regards
Gordon
May 05, 2011 | Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
WHIRLPOOL MODEL ED5FHG SAT FOR ABOUT 3 WEEKS AND WHEN I RECONNECTED IT I CAN'T GET WATER. THERE WAS A BLUE TUBE SOMEONE HAD STUCK INSIDE THE DOOR BUT I DON'T KNOW WHERE IT GOES OR EVEN IF I NEED IT? THANKS
Hi dhbyrdl;
The blue tube is called food grade water pipe. This pipe should be connected to the back of fridge (Bottom RH Side to allow water into the unit). It will either have a push in fitting or require a flare connection. The only other pipe is the clear (white) one connected at the bottom of freezer door that feeds the water dispensor.
Mar 29, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Water underneath the freezer section
Please check for the water passage beneath the freezer. There will be a small pipe and there is a possibility that that pipe path is blocked with ice or dirt.
Mar 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer is not cold enough - ice-cream is soggy! despite putting it on coldest; and the red warning light is permanently on. And I can't find the booklet. Help!
If the coils are frozen up already,putting the setting to coldest is the worst thing to do.Even though inconvenient,try unplugging for substantial amount of time (3 or 4 hours) to allow the coils to defrost.Be prepared for water leakage during this time.If this seems to work , chances are the defrost timer or defrost heating element are bad and the problem will recur after a week or two.
Jan 17, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Ice maker works but water won't dispense
There is a know defect with the freezer side door. read more at http://www.houstongofarappliancerepair.com/Refrigerator.html
Also, If you call and haggle GE they may send you a new freeezer side door. Or, You may actually try turning fridge off, leaving door open for about 4 hours and then try it again. As strange as this sounds it has worked for some of my customers.... When "air-bubbles" get into that line it can freezer inside the door a small section of water line because the insulation in freezer side door isn;t thick enough... More can be read on this problem at http://www.houstongofarappliancerepair.com/Refrigerator.html
goodluck...
Dec 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Nov 17, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
