Question about Cameras
Camera not working when it is switched on
Camera lens not coming out when camera is turned on
    Genius:
  • Cameras Master
  • 1,019 Answers
Boy there sure is a lot of this going around, it is a camera failure that will require a shop repair, you can not fix this yourself.
Posted on Jan 25, 2013
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
I need your help please, I fell with my Nikon camera, the body still works, but the 55-200mm lens does not work again, for seeing through the viewfinder the image is dark. The lens does not hit with...
Okay if you have luck all that's happened is you have jarred the lens contact between the camera body and lens. Make sure the camera is turned off then remove the lens and clean the gold contacts on both the lens and camera body. Remove the battery, install the lens and replace the battery, turn the camera on. If it still doesn't work shut the camera off and try another lens and see if it work properly this will tell you if it's the camera at fault or the lens. Switch lenses between known working cameras. I'm sure you will find the lens has come loose. I only once had a lens come apart from a jar (not impact) and it actual popped apart in pieces.
Dec 10, 2010 | Nikon D60 Digital Camera with 18-55mm +...
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
Camera not switching on
I believe there is a lens error, usually that message appears when the lens are stuck or not working.
Turn the camera ON by pressing the "play" button (to see images only) and if the camera turns ON with no problem, then the problem lies on the lens.
you can send the camera for repair or buy a new lens set from ebay, they go for around 30 dollars, but you have to be familiarized with cameras and very careful in order to install the new lens.
hope this helps.
Feb 02, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Please help - my lens will not come out, once I switch on my camera. It comes up with an E18 message Vicky
E18 error means that the lens mechanism is jammed and the lens cannot extend/retract.
Follow the steps provided below to solve this problem.
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on.If this does not work then try the compressed air. With a fine tip blow off gun and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.If this also does not work then you need to force the lens out .
Hope this helps.
Thanks for using Fixya.
Jan 31, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
I have a Canon Powershot S3 IS and I was looking at picture I had taken and the lens was retracted. I switched to the camera mode and the lens started to come out and hit my leg and stopped half way. The...
format ur memory card ....and replace the cells.....might work...contact the customer care for help ..they mightr be able to fix it ...
May 03, 2008 | Cameras
Wont turn on properly
Ive looked all over the internet for a solution to this very common problem. This is the only one that worked for me. When you turn on the camera the green led light comes on. Hold the camera in your right hand while you turn it on and as the lense comes out, bang the camera (lens facing down)against your left palm repeatedly until you notice the led light briefly turn red then green again. You need to do this every time you turn it on.I think shaking it loosens the jarred lens. This was the only solution I could find and although I was tentative about doing more damage this way, I tried it and it works.
May 19, 2007 | Olympus Stylus Verve S / ?-181 mini S...
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
