Question about Cameras
Camera lens wont come out when switched on
Camera lens doesnt activate when camera is switched on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Posted on Jan 21, 2013
I have a sony alpha a230 camer and just bought a bower 500mm lens but when its atteched the shutter stays lock and wont take a picture. The camera doesnt recognize the lens
The lens doesn't have the electronics to communicate with the camera, hence the camera doesn't recognize it. You need to switch the camera to manual exposure mode. You won't get any help from the camera's exposure meter, so use the LCD monitor and the histogram display. You also won't get any autofocusing.
Nov 04, 2010 | Cameras
Lens wont retract or extend when pushing the power button and cannot take photos. power will not remain on.
Can you turn the camera on by pressing the playback button? This should turn the camera on to view pictures on the card without opening the lens.
Check the tab on the battery door. it should activate a micro switch next to the card slot on the main board. If this is damaged then the camera will not power up.
If the lens is stuck then this will also prevent power up
Nov 15, 2009 | Fuji FinePix E900 Zoom Digital Camera
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
Zoom lenses is extended but wont go back in
Switch on and PRESS the "wide angle" selector switch. (in camera mode)
Now the lens should move partially back in.
If it does not move inwards at all and you do not hear a whirring noise, then the activator motor is defect.(or the lens assy is out of alignment). (or a foreign object has entered the gearing, and stalling the motor)
If you do hear the motor running, then a gear might be stripped.
All these faults do require to take the camera apart.
Mar 08, 2009 | Fuji FinePix F650 Digital Camera
Lens Error
well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
V570 Dual Lens, will not switch to ordinary lens.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
Jun 10, 2008 | Kodak EasyShare V570 Digital Camera
Lens is not opening in the movie mode,unable to record movie also.
normally there are two possible causes for the problem, 1) the connectors of the rotary switch are dirty or not making proper contact. 2) the cable from the rotary switch is damaged. In both the cases you have to get the swith changed.
Nov 01, 2006 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
