Question about Moulinex DG6 Food Processor
My food processor has seized up and no one can open it to repair
Apparently the problem is the screwdiver to remove the screws. Help me get one or where can I send it
  • 142 Answers
If the screws are a star head, go to an auto shop T30 T40 T50
if their a 3 point screw head, find an avaiation tool supplier
Posted on Jan 27, 2009
  • MaxMotion
    MaxMotion Apr 22, 2014
    It looks like a T30/40/50 but it has a peak in the middle. Obviously Moulinex special. It's unclear to me why they prevent me from fixing their device but my lesson learned is: Don't buy Moulinex!
  • MaxMotion
    Just read they went bankrupt. So, other Microwave producers, learn from their fate and produce devices that that you can repair with ordinary screwdrivers :-).
Need to remove the proprietary screws from a Braun CombiMax 700
These are called Torx security bolts. You should be able to find the right size at your hardware store.
Jan 08, 2014 | Braun K 750 CombiMax Food Processor
Cuisinart smartpower duet BFP703 food processor repair manual
Oh some of these answers... the most common issue with blender is that the removable blade unit starts to jam. So :
1. unscrew it, clean it and make sure it turns easy
2. open the unit and replace the fuse that blew up because turning the blade became too hard.
Voila
Nov 25, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
How to tighten the nut on one of motor screws of a 7 cup kitchenaid kfp720 food processor
A gouge in the edge of a plastic button is not the end of the world, it has to come out to effect a repair. I use a sharp knife down the side, you can always blend any little damages to the plastic with the round shaft of a screwdriver.
Apr 28, 2012 | KitchenAid KFP720 7 Cups Food Processor
Kenwood FP460 food processor, can it be opened up to replace a damaged power cord? If so how?
Yes. First, unscrew all the screws from the bottom, then, gently, pull it out. Please note that you need to have basic electricity knowledge in order to properly disconnect and reconnect the power cord.
Jan 19, 2011 | Kenwood Food Processors
I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
Dec 29, 2009 | Robot Coupe R2U Ultra Food Processor
I want to open the base of the processor, but can't find screws
Remove the 4 rectangular rubber pads on the bottom.
Later you will need some Rubber Adhesive Glue to place them back.
This will give you access to the 4 Phillips screws.
I presently own a Cuisinart Food Processor Model# DLC-7.
I hope this helps you.
Dec 29, 2009 | Cuisinart DLC-5 Food Processor
The center spindle on my Magimix 5150 is stripped and needs to be replaced. Any idea if this is a do-it-yourself project if I can buy the part or should I send it out to be repaired?
Just researching the same problem. Apparently your can find the spare parts here:
http://www.magimix-spares.co.uk/Magimix-5200,-5100-spindle-cover-white,-Nylon-driveshaft-/product/104991/104991/
The old one is has push fit on an inner spindle and apparently can be prized off from outside without dismantling the machine. See the link below for further details.:
http://www.howtomendit.com/answers.php?id=47005
Oct 08, 2009 | Magimix 5150 Food Processor
How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Mar 11, 2009 | Cuisinart Food Processors
Moulinex DG6 Food Processor Logo
186 people viewed this question
Top Moulinex Food Processors Experts
Colin Stickland
Colin Stickland
Ross Keen
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
