Question about D-Link DIR-600L Wireless N150 Cloud Router
My dlink dir 600l power light flashing green and will not boot
bpcs
  • 112 Answers
SOURCE: DLINK ROUTER DI-624M
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
Posted on Dec 29, 2007
SOURCE: how to put security protection (wep) on dlink dir-300?
go into your local ip modem ip and login with admin and paasword. then look up every tab until you will find the wep key tab ;D
most common ip's is:
192.168.1.1
192.168.0.1
192.168.99.1
Posted on Feb 11, 2009
  • 85 Answers
SOURCE: dlink dir-615 won't power up. I think maybe it
Have you checked the power supply to see if it is supplying the rated voltage to the plug that plugs into the router. It should be somewhere around 5 - 15 VDC. That's a great place to start. If you have voltage there then repair of the router will require someone with knowledge of testing ICs and soldering.
Posted on Jan 15, 2010
SOURCE: Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hi.. all,
i am facing the same issue.. my new DIR-615 , when plugged with power cord ... make the power led blink continuously... and hence so, no network is accessible neither wifi works in simple terms noting works, no combination of power cord with network cable with computer works.
i have even tried resetting using the reset button.. but still the power button keeps blinking.
and yes it was working in past, its a brand new product(3 months old).
Please help and its urgent..
thanks a lot for your help..
Regards
Dharmendra
Posted on Apr 28, 2010
mace1mace
  • 1138 Answers
SOURCE: dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
Posted on May 22, 2010
I am having a DIR 600L router i was using it and it have sudden disconected to my network and no led are working only power button is shown led
Well it may be due to some problem so
check your router and modem.
check your router setting according to your ISP.
check your firewall setting for blocking network.
Try to update your Firmware.
If still not working than reset your router and configure again. if all of this will not work than contact to http://support.dlink.com/index.aspx
and D-Link Router Support for more technical help.
May 24, 2014 | D-Link DIR-600 Router
Why my d link dir 600 has no wifi signal
What is colors of lights in your dlink box
skype id : johnwalker800969@gmail.com
May 07, 2014 | D-Link DIR-600L Wireless N 150 Home Cloud...
Not able to configure "Router - D-Link DIR-600L Wireless N150 Cloud Router" to hathway dsl - Thomson Modem
Go to dlink.com and go to FAQ, "D-Link Systems DIR-600L Wireless-N150 Cloud Router setup" and you will find a S-B-S how to.
Jan 16, 2014 | D-Link Systems DIR-600L Wireless-N150 Home...
How to connect dlink dir 600l router with bsnl modem having pppoe connection
You'll need to hack it and put DD-WRT or OpenWRT on it for a decent PPPOE connection.
Sep 19, 2013 | D-Link Computers & Internet
I am trying to connect my ipad 3 to my dlink 600L. It will ask for password but will not connect when password is putin
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fast D-Link Wireless Router Security Setup
Apr 19, 2013 | D-Link Dir-600l Wireless N 150m Home Cloud...
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
D-Link DIR-600L Wireless N150 Cloud Router Logo
517 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
