Question about GE GTDP300EMWS Dryer
How to open this dryer to replace mica heating unit.
Massive sparking and noisy when switched on to heat
There are 2 things that cause the massive sparking:
1. you placed inside the microwave oven a metal plate or one with silvery or golden drawings;
2. the mica sheet that covers the magnetron window is compromised (has holes, it is cracked) or it is covered with burnt (carbonised) food.
You have to carefully inspect the mica sheet and wash or replace it, if necessary. Hope that helps.
Regards,
Dan
Oct 10, 2016 | Microwave Ovens
My Microwave is arcing due to its demaged Mica sheet. Can I replace it with any other ordinary Mica sheet cut to its original size & fit in its place? Will it work? Or are there special Mica sheets...
Hello.
Yes you can buy mica sheets made for microwaves at appliance repair/parts shops.Scissors work well for this. A razor knife might be needed for notches etc. If so, several shallow cuts work better than trying for one deep one, as your not as apt to slip. I usually put the leftover material in a plastic bag and tape it to the bottom of the unit so I could find it the next time.
Hope this helps you.
fil
Mar 06, 2011 | Microwave Ovens
No heat, power good. 120 each leg. drum turns. ran diagnostics. no error codes. t07 reads 73f, to8 reads 74f, t09 reads 5.01. suspect heater element is open. model is DBVH512EF0WW. would have thought error...
better but the restring kit comes in bracket # WE11XM30 heater assy mica heater but i would check tstat on top left of heater 2nd thermstat in ward rivited on metal plate thats usually the bad one and the thermistor on blower assy # WE4M336 or get complete asymbley 512 on parts break down and 240 on parts breakdown thermistor
Jan 31, 2011 | GE DBVH512EFWW Dryer
I have an Amana LG4319w/l2 gas dryer converted to Lp gas. The ignitor comes on but will not ignite the gas. Theis happened before and the technician replaced the ignitor and said the ignitor must dray a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | Amana Dryers
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
GE ZMC1095 Series microwave sparks on bottom exterior?
replace the mica plate and clean around the mica plate any grease or durt.
check also the capacity value bethween 0.85 and 1 uF
Feb 15, 2010 | Kitchen Appliances - Others
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Magnetron tube and mica waveguide cover
Unfortunatey unless the unit is a high end oven by the time you pay for the parts and labor you could probably get a new one. Don't forget if you have to replace these parts already who knows what else is about to happen. I hope this helps you out.
Nov 26, 2008 | Sharp Microwave Ovens
No heat electric dryer
Hi , what the repairman say is true , that parts are available in appliance store or any electrical shop., bring that sample to the appliance store for sample . that is like sensor it will open when it broken the filament of heating unit will not heat up if that parts will open., it is one one who limit the heating allowed by machine .
Feb 21, 2008 | Dryers
Replaced timer however time does not count down and dryer won't heat up
one thing to check it the voltage coming into the unit make sure you have 220-230 volts at the plug if so you want to open the back little panel where the cord goes in and check your terminal block and cord connection PLEASE unplug b4 you open the panel A dryer will still tmble but wont heat or advance if that leg(110volts) is not there and the other one is
Jan 20, 2008 | Whirlpool LER5636P Electric Dryer
GE GTDP300EMWS Dryer Logo
18 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
