Water full evantair portable air conditioner - Heating & Cooling
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
  • 10865 Answers
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Posted on Jul 06, 2010
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
heatman101
  • 43501 Answers
SOURCE: portable air conditioner not collecting water
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 22, 2010
caroldon
  • 17129 Answers
SOURCE: My NewAir ACP-1000E Portable Air Conditioner says
Check the float thaat is the sensor to indicate the water level to the micro controller. The wires are cut or the float is deffective .
Check and replace.Credit if helpful with this tip.
Posted on Aug 24, 2010
  • 1833 Answers
SOURCE: Need to find a manual
There is no manuals available right now for Evantair AC TWYL-3109R. You have to wait till it's availability.
Posted on May 30, 2011
My DeLonghi PAC A110L portable air conditioner is leaking water. How do I fix this?
Hallo
If an Air Conditioner is on cooling then the Air Conditioner also removes humidity from the air any Split Unit, Window Wall A/C you name it... Any A/C on cooling dehumidify the air in the room.
To decrease the volume of the water:
1) Clean Air filter/s
2) Keep doors and windows close( can open now and again).
I don't know how that portable A/C of your look like but I believe theirs a water pan inside that needs cleaning I think it's full.( best is to service the hole A/C).
Hope this was useful.
Regards
Jun 09, 2016 | DeLonghi Heating & Cooling
Evantair water tray
you have problem with the evacuate sistem pipe condensing
Jan 04, 2014 | Heating & Cooling
DeLonghi (W160B) Portable Air Conditioner "No Water" symbol is still on despite the water tank being full
Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Dec 23, 2012 | Heating & Cooling
My portable air conditioner is beeping and saying full, how do i get it to stop beeping
Portable air conditioners work much like a dehumidifier in that they remove moisture from the air. This condensation accumulates in a container that may need to be emptied. Check to see if there is a removable container full of water.
Nov 15, 2011 | Soleus KY-34 Portable Air Conditioner
Fedders AEP09D2BCOM Portable Air Conditioner. The unit shut off and the buttom with a triangel and ! is flashing
That flashing triangle indicates that the water collection tank is full and must be drained.
Aug 01, 2011 | Fedders AEP09D2BCOM Portable Air...
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
Comes on and runs then cycles off, and may not come back on. fans run every thing seems to work compressor dose not come back on.
if a portable air conditioner, is the water tank full of water ? if so empty it.
Other option for any a/c unit (not just portable unit) is that it has a gas leak.
Apr 21, 2010 | Genie Aire PACR12 Air Conditioner
Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Oct 11, 2009 | Windchaser Portable Air Conditioner
The E5 code is on, emptied the water tank; still on
AC Water Level Sensor for C475 and C360 Alen Portable Air Conditioners This is a replacement water level sensor for the C47store.alencorp.com/product-p/acwaterlevelsensor.htm. Check out this sight. Good luck
Aug 31, 2009 | Alen C475 Portable Air Conditioner
MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Jul 24, 2009 | Danby 7,000 BTU Portable Air Conditioner -...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
