Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
Helicopter not stable
While flying, the helicopter is not stable. it takes off and starts circling in wider and wider circles. I have tried to correct with trim but this is happening while its vertical axle is stable and the nose of the helicopter points always in the same direction, while circling. I guess that the gyro does not work correctly. If so can the gyro be replaced?
  • sergio_sciar
    sergio_sciar Jan 24, 2013
    Hi I have tried that and it seems it reduced the TBE behaviour but did not stop that .I have ordered a new inner shaft, and see what happens once replaced
    New Friend:
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
Posted on Jan 22, 2013
  • sergio_sciar
    sergio_sciar Jan 24, 2013 Hi I have tried that and it seems it reduced the TBE behaviour but did not stop that .I have ordered a new inner shaft, and see what happens once replaced
3 Suggested Answers
SOURCE: My S107 does not hover
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
Cheers!
Posted on Jan 05, 2011
SOURCE: so i have the syma
Make sure the drive shaft is seated properly. Gently, but firmly push it down towards the body both above and below bottom rotor. Also check shaft for any hair, thread or such thing that may be wrapped around it.
Let me know if you're still having issues, and we'll dig a little deeper.
PvT
Posted on Sep 14, 2011
Why do some small planes and helicopters just fly around aimlessly?
Students and certificated pilots both are required to remain current and to have a check ride (flight review with an instructor) every 24 calendar months. The ones you're seeing are probably going out to the practice area to practice their flight maneuvers. If a pilot doesn't practice regularly his or her skills can deteriorate rapidly.
Jan 04, 2017 | Aircrafts
Iwont lift just spin
we have tail motor is burned out change it that's why it keeps going around in circles and it doesn't fly
Dec 06, 2014 | HobbyTron Gyro Nano Spy Copter Remote...
Helicopter will not fly, just goes in circles
try pressing right or left on the remote or try flicking the joystick forward slow
Feb 17, 2014 | RC Helicopter Select Sanhuan SH 6030 C7...
My 9116 double horse RC helicopter just spins clockwise in circles, on the ground or in the air. I can hover it, but only spinning. What could be wrong?
Air Hogs remote control aircraft are designed to be easy to fly and use, and rarely have flying issues. However, there are the occasional issues that the company can't really predict. Some Air Hogs helicopters, for example, have a hard time flying forward without some assistance. If you're having this problem with your helicopter, this can be annoying, but it is not the end of the world. There is as solution, and it's easier than you might think.For more information:
http://www.playgroundmats.co.uk/ Playground Mats and Playground Flooring Tiles Soft Play Equipment
Jan 10, 2014 | Toys
I crashed my Apache onto a table and when I try to fly it, It keeps spinning out of control. To my knowledge I don't see anything broken. It spins to the right. Please help! thanks!!!
It sounds like your tail rotor is acting up or missing. It keeps your Helicopter from flying in circles.
http://www.start-flying.com/new%20site/heli1.htm
Oct 04, 2010 | Apache RC Mini Helicopter AH-64
Roomba starts out in a circle goes wider and wider then all at once goes in circles.
when it starts doing that hit the start button again then wait a few sec.
Jul 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
268 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
