Question about Ovens
I would like to see a picture of the control panels for a Ariston FM81R IX Aus wall oven
The markings on the control panel have been rubbed off over time.
SOURCE: Ariston underbenchoven - Model FM81R
I also have a copy of the manual
Posted on Sep 14, 2008
SOURCE: Help with Ariston Oven
If you want the manual, I can send it to you.
Posted on Dec 08, 2008
dltatsjc
  • 54 Answers
SOURCE: Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Posted on Oct 12, 2009
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
SOURCE: Oven (Ariston FM 22M IX) Readings faded out...
I have the same problem. I need a manual or pictures of the dials for this oven have ben cleaned off!
please help us
Posted on Jul 17, 2010
Ariston tc720 dials have rubbed off
We had the same problem when our cleaner rubbed off the markings. Ariston "customer services" were very unhelpful (the model is now so old they don't offer any replacement facias for it) but managed to get replacement stickers from Mark at
http://www.ovenlettering.co.uk/. They come with a diagram for all four dials showing where they should go and are very easy to apply. Would highly recommend.
Jan 19, 2014 | Ariston Technologies Ariston FO98P...
I have just moved into a new home with Ariston FB 52 IX AUS and there is no manual and the pictures around the knobs have been rubbed off could someone please help me. thanks
Hi we are in the same situation and phoned the NZ office that deal with Ariston and they stated that is costs $136 to replace the facia panel. She stated she would send me a manual a week ago and still nothing. She stated that there are no Ariston facias in Nz and they don't know when they are coming or if they are going to be coming in. Would definately not buy an ariston oven.
Good luck to anyone else in the same position, I wish I knew what each dial was for on mine.
Maree.
Mar 29, 2013 | Ovens
Ariston FM 51 IX GB Oven replacement control markings
Here you go...
http://kitchen.manualsonline.com/manuals/mfg/ariston/fm_51_ix_gb.html
Nov 10, 2011 | Ovens
I have moved into a new apartment which has a old oven installed. Model: Ariston C 34S G1(X) EX. I find the markings on the panel cleaned off.... can you help me with a manual or atleast the pictures of...
please download your exact ariston c 34s G1 x ex model user manual as under:
http://www.downloadbooklets.com/booklets/searchBooklet.do;jsessionid=D853DE5228C47CD663A9DB6F6CA04067
Aug 04, 2010 | Ovens
We are about to move into a house with a Ariston wall oven, model no: FB 86 C. All the symbols around the 2 knobs have been rubbed off, is there a transfer or someway of finding what the symbols should...
This is a normal feature for this brand. The decal comes off when cleaning with anything other than pure water. They will sell you a whole new oven front for about $100 so you can do it again next time you wipe down the front panel when cleaning your work top. Please complain to Ariston head office and tell them what you think of their product. The manual doesn't show the detail so I guess you will have to buy either a proper oven or get ripped off by Ariston for a new panel ( you could always send the new panel back after copying the letters). I'll never buy an Ariston product again.
May 02, 2010 | Ovens
please help us
Feb 10, 2010 | Ariston Technologies Ovens
Marking have worn off on front cover of ariston FM 22 M IX - oven
Try using ovenlettering.co.uk - I recently had same problem the symbols are easy to apply and look great. A brand new oven in minutes, speak to Mark - he can guide you through the process - very helpful
Mick Lawry
May 17, 2009 | Ariston Technologies Ariston FO98P...
Dec 05, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
