Question about Casio G-Shock G3110-1V Wrist Watch
Can i buy a new lcd display fo my g3110
New lcd part please
My DZ 7241 watch analog watch does not turn on?
please ckeck the crown of your analog time if it is pressed down, if it is pressed it is possible that even if it is a brand new watch, the battery has no power at all.. it is maybe that your newly purchased watch is been in its selling showcase fo a long time, so that the watch movement consume all the power of the analog's battery.. you have to replace the battery of your analog., Note: your watch has three batteries. I hope this will help..
Feb 05, 2013 | Diesel DZ7241 Mens Watch Stainless Steel...
Cant turn the alarm off on casio g3110
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 07, 2011 | Casio G-Shock G3110-1V Wrist Watch
How do i change display color?
Hold the top left button down until you hear a beep and the seconds start to flash. Then push the bottom left button (7 times) until COL starts to flash above the seconds. At this point, you can use the 2 right buttons to scroll through the color options. When you're done, press the top left button to set and lock the color you've chosen. Hope that helps.
Dec 20, 2010 | Casio G-Shock G3110-1V Wrist Watch
How do I eliminate military time?
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Nov 11, 2010 | Casio G-Shock G3110-1V Wrist Watch
I stupidly threw the instructions for my g shock 3110 watch out and i dont kno what some of the features are like when im going through the modes after the timer mode you come across one which looks like...
The DT is Dual Time Mode, I use it when on holiday in a different time zone. Another example is you could set it to the time in another country if you regularly phone family there.
Oct 31, 2010 | Casio G-Shock G3110-1V Wrist Watch
I just got a new G-Shock watch and the date 9/28 thinks it is Thursday. Any way to correct this? Thank you. Kate
If you haven't any instructions, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Sep 28, 2010 | Casio G-Shock G3110-1V Wrist Watch
I have a Casio 1470 pathfinder watch. I did not use it for several years The batteries ran down, have replaced them and now have no display or functions
mcdevito75 here, I would see the jeweler who installed the new batteries and ask to have the battery install double checked so they are makeing proper contact with the LCD movement. In the meantime you can try to hold down the MODE button for a few seconds and see if the display appears, also if the display screen has turned very dark, your Casio may have had it, as the LCD display could have gone bad. New batteries should bring up a display even after the watch has been stored. Hopefully the display is still a grayish color and the new batteries need re-alignment.
Aug 11, 2010 | Casio Watches
Put new battery in wave cepor now can't get it in proper time zone. # on back, boxed [2735] WVA-105H
It may well be that the digital time displayed on the LCD is correct, but the hands (referred to as analog time in the manual) do not match.
If this is the case, to set the so called analog time:
Press the lower left button six times to enter HS (hand setting) mode.
Then press and hold the upper left button until the display starts to flash.
You can now use the two buttons on the right to move the hands forward or backwards to exactly the same ime as the digital LCD display.
When finished adjusting the hands press the upper left button one last time to exit.
Jan 07, 2010 | Casio WVA105HDA Wave Ceptor watch
New watch strap
I got mine from ebay. Its tough to install but I used a pen knife and a very small sdrewdriver. you can do it.
Good luck,
Techjoel
Feb 17, 2009 | Casio G-Shock G3110-1V Wrist Watch
Lost alarm & all Beeps on Casio G-Shock G3110 Wristwatch
You probibly lost a little spring that goes into your movement that makes contact the curcit board and the back of your watch. It is VERY small and alot of people who change their own batteries don't even see it when they open their watch and it falla out . If I knew your address I would send you a couple. If you look at the back of yhe inside of your watch you will probibly see a hole with a LITTLE straight line comming off of it, that is where that spring goes. NOW you MAY not have grounded your watch, that could cause that to happen to. Open your watch and look at the back. You should see a AC marking. Take a tweezer or a metal object and touch the ac and the top of the battery.Then re-set your watch time. I'm hoping that is it, if not you need that spring.Let me know what happens, and if I can assit you with any other watch or jewelry problem.Also we at home are proud of you!!! Good Luck!!!
Jul 09, 2008 | Casio G-Shock G3110-1V Wrist Watch
Casio G-Shock G3110-1V Wrist Watch Logo
27 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
