Question about Miele Vacuums
Miele Solution 5281 motor problem - can it be fixed?
On start up gives a bubbling noise and smells slightly of burning
    Novelist:
  • 171 Answers
You cant repair the motor but it is not too hard to replace the motor. I have made a video showing how to replace the motor on a miele S5311 which is a very similar machine. The part number for the Miele S5281 motor is 9271290
Posted on Jul 23, 2013
ThinkVacuums
  • 144 Answers
SOURCE: Slight burning smell when dc07 is in use
Sounds like your belt can either be rubbing against something or its stretched out. Either way you should check into getting the belt changed.
Posted on Aug 14, 2009
  • 126 Answers
SOURCE: burning smell
Replace the belt. It is probably stretched and is slipping. This will produce the smell your describing. These belts should be changed at least once a year.
Posted on Jan 12, 2008
  • 15290 Answers
SOURCE: Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Posted on Mar 24, 2010
  • 694 Answers
SOURCE: Hello can you help me
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Posted on Jan 02, 2011
Testimonial: "Thankyou very much"
wentlanv
  • 710 Answers
SOURCE: The motor in the Kenmore canister started smelling
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Posted on Mar 30, 2011
Miele vaccum cleaner wont run
If dirt or other debris collect around the armature of the motor the stator will no longer communicate and turn. Usually the brushes wear down and need replacement also. Once you replace the brushes and clean the interior of the motor housing, the motor should start up again. AS long as there is no smell, the motor parts are still in tact. You will also need to replace the belt from the motor spindle to the brush.
Feb 17, 2018 | Miele Vacuums
My Miele Hepa 5281 stopped working for no apparent reason. No burning smell etc. I've replaced the fuse on the plug but it's still not working. Any suggestions on what could be wrong a
Could be a break in the mains lead. Usually where it enters the machine and gets stressed. Some motors have a thermal cut out or thermal fuse fitted to them. If the motor overheats it breaks the circuit. Some of them reset when they cool down, some are a one shot device, when it blows it has to be replaced. Could also be faulty brushes on the motor not making proper contact because the are sticking or worn.
Dec 18, 2014 | Miele Vacuums
Riccar RSL4 Supra Lite Very Noise/Slight Burning Smell
I am looking for a new motor for my 8920 Ricaar Vacuum. Can you lead me in the right direction. I can put it in my self. I replace them before. I used Ricaar for 25 years. Love them
Jan 02, 2014 | Riccar Vacuums
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My miele, is 6yrs old , no problems in past, new bag and filter, after using for roughly 10 mins, i can smell a strong burning smell, any suggestions how to fix this please , regards zoe
Hi Zoe,
The strong burning smell is almost always an indicator of a motor being burnt out. I have made a Miele repair video but am not sure which model you have so it may not be exactly what you need.
Aug 13, 2013 | Miele Vacuums
My miele s571 hoover is humming from a normal sound to a real low hum sound and their is a smell of burning it even through my smoke alarms off what would be wrong or is it worth fixing
It could just be a slipping belt, hair and lint get under the belt and make it stretch the it slips and the spinning drive post heats it up until it starts burning.
Jun 14, 2010 | Miele S318 Bagged Canister Vacuum
My Miele Solution HEPA 5000 vacuum cleanr gives off a burning smell but will continue to run with a varying motor tone. I have not run it for more than a minute like this. I have reviewed responses to...
Check both the bag and the HEPA filter behind the bag, torwards the motor. The HEPA filter could be clogged. Love these units but it takes clear attention to multiple filters.
Mar 06, 2018 | Miele S318 Bagged Canister Vacuum
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
Does not vacuum effectively. It smells like it is burning. I have only had this one year and hardly use it. When I brought it to a local vacuum repair place, he wanted to sell me another one, and, of...
The burning smell may be the motor that's on its way out. Vacuuming with a blocked pipe or sucking up liquids may cause the motor to burn prematurely. The motors arent very expensive, but on the small vacuum cleaners it is sometimes more cost effective to go for a cheap second hand vacuum than to fix it. Depends on if the guy that fixed it is trustworthy, but i can guarantee you the secondhand machine will not have a lifelong guarantee on it. ask for prices on the motor and decide which you can afford.
Oct 28, 2009 | Miele S548 Bagged Canister Vacuum
Vacuums Logo
571 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
