TD3101_3104 Video / Audio Card - Televison & Video
WHAT DOES IT DO I HAVE NO IDEA HOW DOES IT WORK?
A sound card (also known as an audio card) is an internal Computer expansion card that facilitates economical input and output of audio signals to and from a computer under control of computer programs. The term sound card is also applied to external audio interfaces that use software to generate sound, as opposed to using hardware inside the PC. Typical uses of sound cards include providing the audio component for multimedia applications such as music composition, editing video or audio, presentation, education and entertainment (games) and video projection.
Sound functionality can also be integrated onto the motherboard, using components similar to plug-in cards. The best plug-in cards, which use better and more expensive components, can achieve higher quality than integrated sound. The integrated sound system is often still referred to as a "sound card". Sound processing hardware is also present on modern video cards with HDMI to output sound along with the video using that connector; previously they used a SPDIF connection to the motherboard or sound card.
I hope this helps you.
Apr 29, 2016 | Computers & Internet
How can I record audio onto the SD card?
what is the model of the cam?
some cams only do video
depends what its saving the file as
may be your software that wont play the audio but plays the video ok
check the codec used to save the audio
Apr 26, 2015 | SWANN Home Security
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
How do i play whats on the memory card nothing plays video only audio. or what do i need to convert it
First, make sure you have it on CARD (and not DISK), and on the "playback" (and not record) mode. Next, does the camera play back other video clips normally, but just not a specific clip ?
Does the selected video clip frame (index) shown on the LCD screen have a picture ? If not, i.e. it is blank (dark), then it is likely that no video was recorded (i.e. just the audio) when you were shooting that video clip.
If there is a picture (of the video clip frame index on the LCD screen) and only audio is playing, try downloading the clip (from the SD card) to your computer, or simply try to play the video on the SD card (inserted directly into your SD card reader on your computer, or via a USB SD card reader) and see if the video clip will play normally on your computer.
Jan 09, 2011 | Samsung SC-DC173 DVD Camcorder
I'm attempting to install a ati radeon 3450 in the agp slot. The end result I'm shooting for is HDMI with audio. I only hope for 2 channel audio, not true digital audio, and as I understood the card's spec...
An HDMI interface passes both "audio" and "video" signals.
So, the "trick" will be to get your computer to "multplex" both "audio" and "video" into the HDMI interface. Low-end video-cards only output video.
You may need a patch-cord (line-out on your sound-card to line-in port on the video-card). Or, maybe the device-drivers that come on a CD-ROM with the ATI card include the necessary software to "simulate" such a patch-cord.
Apr 18, 2010 | Pine Technology XFX Mach4 P4XEMVB...
Kworld TV88x audio problem
How are you plugging it in to the capture card? Some cards are video only, You have to buy a card that does video and audio. Most have an adapter that connects to svideo, and rca. I would go with a usb unit. That is what I use. Thanks
Dec 27, 2008 | Computers & Internet
How to set my audio to hdmi while connecting my tv to my pc. my graphic card is Gforce 9600
I am pretty sure that the nVidia GeForce 9600 series of video cards use a DVI connector, not an HDMI connector.
While the HDMI connector has the ability to transfer digital and analog audio across it, the DVI cable does not.
You can connect a DVI video card to an HDMI display, and it is compatible for the VIDEO portion, but again, the DVI connector does not output audio at all.
You will need to connect the audio outputs of your audio card or motherboard to your TV by using a 3.5mm headphone jack to RCA jack adapter.
Dec 08, 2008 | Sharp Audio Players & Recorders
Turning my saa7130 into my default audio card
I went through the same issue when I bought this unit new. After going round and round, I learned that you MUST use the little dual plug audio wire to put on end into the video card OUT plug (green out line) and the other end into the Audio Card IN (blue in line). That will splice your TV Card into your audio card and sound will miracuosly appear (once you fine tune your audio outputs!). Hope that helps!
Jun 27, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
S-video on pc
the audio gets plugged into the sound card (or on-board sound system) audio input jack.
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
Electro Med Services...
