Flexicom boiler makes a loud noise
Its so loud i have to turn it off
3 Suggested Answers
jcpark50
  • 52 Answers
SOURCE: boiler making a loud hissing
sounds like a stuck expansion valve, the compressor makes pressure, but it can't be released to absorb heat from the desired environment. You could go to the manufacturer's website, request a detailed diagram of your system, find the expansion valve and order a new one. Can you put it in yourself and recharge the system? Probably not, call a repairman.
Posted on Nov 07, 2008
  • 4736 Answers
SOURCE: We have just bought a
This can be caused by several things. Incorrect Gas to Air mixture in the burner air intake valve. . Debris in the gas line to the boiler. To high a gas pressure. Depending on whether you installed this unit or not, will determine if you should try to repair or troubleshoot these issues. If it was professionally installed call the company that installed it. The only one you can't troubleshoot is the gas pressure. That needs to be done by a certified gas technician.
Hope this helps steer you in the right direction to solving the problem.
Posted on Mar 15, 2011
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
Banging boiler
How to remove the air from your boiler heater The boiler is probably air bound, and the system needs to be purged of air. The link is for an informative video. It will explain the various parts/ produdures to purge the system.
Bleeding Hot Water Boiler
Apr 09, 2014 | Washing Machines
How do I use the analogue glide down timer
1) Copy following link for setting analog timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/pdf/Glowworm-flexcom-analog-timer-manual.pdf
2) Add a comment Dec 2012 for additional information.
Dec 12, 2012 | Hardware & Accessories
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Optimax he 31 c whirs loudly but makes no heat
After calling an engineer it turns out it was a faulty fan (The loud whirring should have given this away...) Apparently this is a relatively common fault with this type of boiler. Only solution is to replace the fan which, as of 2010 is still under warranty and can't be bought separately, so you'll need to call Ferrolli.
Jan 08, 2010 | Heating & Cooling
We seem to have developed a problem with our boiler, worcester 20/25 heatsave. Every time we turn on a hot water tap, when we turn the tap off, there apears to be a loud noise from the boiler or pipes for...
it seams the valve that senses water flow is not operating properly,causing the boiler to keep heating the water when it has nowhere to go,i,e the taps turned off,thus boiling the water.
Jan 12, 2009 | Heating & Cooling
I have a multifuel stove which runs my central heating system from its back boiler. When it gets really hot there is a loud clicking and knocking sound from the rear of the stove where the thermostatic...
That clicking and knocking noise you hear is called cavitation. It's when the bubbles of steam are cooled down rapidly and implode upon themselves. Cavitation is not a good thing to have in a boiler as it can cause dramas. This cavitation is more than likely because the boiler is firing too hot. A service technician should be called to turn the regulator down a little bit.
Sep 18, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
