Question about Keurig Coffee Makers & Espresso Machines
I would like to know where I can send my keurig for repair. It doesn't brew properly anymore.
    Master:
  • 240 Answers
Contact Keurig (866-901-BREW) for help
Posted on Nov 25, 2013
  • 11 Answers
SOURCE: keurig B50 brew basket lost
Brew basket? I believe also called the cup holster. Call Keurig, I got the replacement from them. I didn't find it anywhere else. So far it was free of charge.
Posted on Dec 07, 2008
heatman101
  • 43501 Answers
SOURCE: Our Keurig doesn't fill the cup. It generally
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 25, 2011
heatman101
  • 43501 Answers
SOURCE: my keurig just stopped working
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: Why doesn't my Keurig Spceial
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: i have a keurig b70
heatman101
Posted on Sep 02, 2011
Why would my keurig only push through a small amount of water from a pod but give a full cup when using a fill your own pod?
Hmm, this is a very interesting question. My experience tells me it is probably two things that are happening with your Keurig. It takes a bit more air pressure to push the water out of the heater through a new pod than pushing it thorough a do-it-yourself pod. This would have to do with how much coffee is in the new pod, vs. your own pod and the grind of the coffee. My guess is that the grind in the new pod is finer than the grind you are using in yours. Anyway, the issues are probably experiencing are either a weak air-pump motor "and" a leaky solenoid valve, or a combination of both. The air pump motors are notorious for getting all rusty and corroded on the inside due to water leaking from a bad solenoid mounted directly above it. Once the motor armature starts to get rusty it starts to lose power because it doesn\'t spin freely anymore. In addition, the solenoids used on this machine are also notorious for leaking and the internals become corroded. Once the inside of the solenoid becomes corroded it gets sticky and will not firmly seat closed during the brew cycle. If the valve doesn\'t close all the way it will allow some of the air from the air pump to bypass the water heater and flow into your external water reservoir. During the brew cycle of a new pod do you notice any air or water draining back into the external water reservoir? If so, you have a leaky solenoid. Bottom line is, if you are not a technical person, you\'ve got big problems with your machine. This explanation is getting a bit long and boring (I know), so if you want to know your options to fix it or return it for a new one, you will have to send me another note. The repair is a pain! Good luck and I hope this helped.
Aug 05, 2014 | Keurig Platinum B70 Coffee Maker
Doesn't heat or brew.
Send to Factory for repair.
Oct 19, 2012 | Keurig B30 Mini Coffee Maker
When I press Brew, it doesn't do anything - it says brewing... could I have set a timer on the machine?
heatman101
Sep 10, 2011 | Keurig B60 Coffee Maker
Brewer rumbles but doesn't brew or send water through
heatman101
May 06, 2011 | Keurig Special Edition B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
377 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
