Question about Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer
Maytag Model MGD6400TQ Front Door Won't Shut Completely
The metal catch that should engage the metal stud is loose. I'm having trouble removing the catch to either replace it or repair it.
  • James Metcalfe
    James Metcalfe Jan 27, 2009
    I have ordered the part and should get it in a couple of days. Hope it works.
  • James Metcalfe
    James Metcalfe Jan 30, 2009
    Thanks aborcass. That did the trick. Now I need to find out why the same dryer makes a loud whirring sound as the drum turns. Clothes dry just fine, but the noise is annoying.
    President:
  • Maytag Master
  • 2,651 Answers
Heres the aprt number for the "catch" , if you have a problem removing it i would simply push it into the door, it will fall to teh bottom , no need to worry about ti wont hurt nothin.. its meant to grab and snap into place as you push it into place, whichis why itdoesnt wnat to pull back out the same way W10111905
Posted on Jan 27, 2009
  • Ron Coons
    Ron Coons Jan 30, 2009
    sounds as if perhaps there might be something caught with in the blower wheel assy. this acan be acessd by removing the front panels
Door is locked but won't agitate/spin and the latch assembly clicks a few times then give error code FL -
That is Failed Lock. If the door is not completely shut and the lock can not engage after several attempt you will get this code.
Mar 17, 2016 | Maytag Neptune MAH6500A Front Load Washer
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Bravo XL Dryer not blowing HOT air
Can you look inside the door and tell me the model number? Electric or Gas? Here are some model numbers.
ELECTRIC MODELS: MED6300TQ, MED6400TB, MED6400TQ
GAS MODELS: MGD6300TQ, MGD6400TB, MGD6400TQ Sea Breeze
Feb 28, 2013 | Maytag Dryers
On Maytag dryer model # MDE9316AYA how do I get the top off? One of the fins inside the drum is loose, and I hope I can reach the screws to tighten it up by removing the top, but it won't budge and...
Opening the cabinet of these machines begins with the cabinet top. There are two spring catches located just below the cabinet top that secure it to the rest of the unit. These catches are located towards each side edge. Use a putty knife (or some other thin and flat object) to slide in under the cabinet top to disengage each of the clips. You can now lift up the cabinet top.
With the cabinet top lifted, you will see two screws located inside the top of the cabinet front. Remove each of these screws and lift the front panel to disengage the two clips found at the bottom. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
Jun 13, 2011 | Maytag Dryers
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let...
sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Oct 13, 2010 | Kenmore 500 6952 Dryer
Seems to be ppower, cheched fuses where the box
this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Nov 04, 2009 | Maytag MDE2600 Electric Dryer
My dryer door will not stay shut. It seems like the little clip that is supposed to keep it shut no longer catches. Do these clips wear out? It looks fine and seems to fit- just doesn't catch
Take a second look at the door.
Is the spacing the same between the door top and bottom as it fits into the front cover?
Over time, people/children will rest weight on the door as it swings open, bending it downward. You may see rub marks where the door is hitting the bottom jamb.
Pull hard to bend the door back up, OR unscrew and re-tension rhe 4 screws that secure the hinges to the front frame.
The door should close more completely now, Spray a little silicone lube on the latch.
good luck and I hope this solves the problemn.
Aug 13, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag drum baffle came loose and catches clostes when drying
I had the same problem and just fixed it. First, open the door and remove four screws, two are holding the door on and the other two are in the same place on the opposite side. Lift the door up and pull it out to remove it. Set it aside. Pull the front panel down. Admire all of the **** that has collected inside the dryer. Next, there are two dark colored metal clips holding the top down on the upper right and left. Remove the hex head screws holding these on. Wiggle them to release them and take them out. Now the lid will lift to reach the screws holding the fins on. Tighten as necessary. Now would be a good time to get the shopvac and clean the lint and junk out of the dryer. Reverse the process to put it back together. Problem solved!
May 24, 2009 | Maytag Dryers
Dryer door won't shut
you will have to adjust the catch to line up and secure it ,
good luck !
Jan 27, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
499 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
