Question about Sony HVR-M25U HDV VCR
Stuck tape and red light
Deck is not responding
    New Friend:
Did you ever get an answer on this. My deck just did the same thing. Please let me know if you don't mind. matt@mustangintl.com
Thx.
-MW
Posted on Aug 16, 2014
I have a rs-hd560 technics separates hi fi, tape deck broken
Malcolm hi! The tape decks are normally interchangeable as a unit and if you have a remote control that also operate your Hi Fi then you are stuck to the model.
Sep 11, 2014 | Audio Players & Recorders
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
Defective cassette adapter for iphone 4s. stuck in side of the cassette deck
take the deck apart, get the tape and put it back together or see if you can find someone who fixes decks and ask them to take the tape out
Jun 16, 2012 | Dynex Mp3 Stereo Cassette Adapter Dx-ca103
Just bought a used Sony TCWR610, to reproduce some valued cassettes. Cannot get the B deck to record. There is a little red light that comes on that says REC, but deck does not turn as I start the tape...
I have the same tape deck. To do a copy on this machine you first press the normal speed button below synchro dubbing, then hit the pause button on the recording side to start the copy. It will automatically start both decks.
And to stop the recording hit either of the stop buttons.
Jan 07, 2011 | Sony Dual-Deck Cassette Player/Recorder...
A tape was stuck, As I tried to get it out the
I geuss the timing of the deck is off.Realignment wil be needed.
Aug 01, 2009 | Symphonic SL260A S-VHS VCR
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Jamed tape
This happens often in my business. Sony DSR is the most delicate cassette compartment out there. It also sounds like the unit is in auto off mode(electronic proublems as well). Please for your sake take this unit to Sony or some one qualified to repair this. You should expect replacement of the compartment and what ever damage occured while removing the tape. Parts for these decks are not cheap, If you had taken it to a service person with the tape stuck inside the monitary damage would far less. The one good thing is this is a consumer unit, if it where a DSR 1500 two models up it would pro and they share parts price for repair x3 across the board.
Dec 17, 2007 | Sony DSR-25 Mini DV VCR
Dual tape deck inoperable
clean the rubber pinch rollers with an alcohol swab. the tape is not getting required "grab" on these rollers and not pulling tape. the auto reverse is an attempt to rewind the tape because of confusion with no tape movement.
Nov 12, 2007 | Yamaha KX-W321 Single Cassette Deck
Sony HVR-M25U HDV VCR Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
