Question about Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air JES9860AAW Bad touchpad
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Jenn-Air Model #JES9860AAW Slide in
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Dec 30, 2010
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
I have a Jenn-Air double oven drop-in prior to 1997 with a FO trouble light showing. What is the usual repair for the failure?
The FO error codes means that a button on the touchpad has shorted out and teh touchpad needs to be replaced. In some cases you will get that error code because the ribbon cable on the touchpad hasa loose connection at the clock. check that the connection is tight.
The error code can be cleared by pushing the clear/off button,if it returns the touchpad will need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air Ovens
F-1 code
Usually a bad touchpad,sometimes a bad control board(ERC).
Try turning off the power to the oven,remove the front panel.
Disconnect,then re-connect the touchpad ribbon.
Reapply power and try the controls.
Sometimes it is just a bad connection.
Mar 06, 2011 | Jenn-Air JJW8330D Electric Single Oven
The Jenn-Air Gas Range Electronic touch control 800. The key pad does not work. You can not set the clock or work the oven. Help.
My Jenn Air has the same problem with the computer touchpad. The only temperature I can get to work is from the left hand column, 411 degrees. I don't want to waste another dime on this oven. I've read so many complaints from other owners. No more Jenn Air products for me.
Nov 22, 2010 | Jenn-Air Ovens
I have 1c 1c code what happening ?
Communication problem from touchpad to board. This is difficult to diagnose and usually turns out being the control bad rather than the board. Hope this helps. Either way they are both pretty costly parts. Good luck.
Mar 10, 2010 | Jenn-Air Electric Double Oven
No control of oven, no response from touch screen. board or touchscreen?
you probebly have a bad touchpad. sometimes you may reset the pcb by unplugging it for 1/2 hr then try again.
Mar 06, 2010 | Jenn-Air JES9750BAS Stainless Steel...
Lost manual what are F1 and F7 error codes
HI, F1-7 IS A BAD CONTROLER RIBBON.CHECK THE RIBBON FROM THE TOUCHPAD TO THE CONTROL BOARD. IF IT LOOKS TIGHT, CONTROL BOARD IS BAD.GOOD LUCK!
ERIC
Jan 21, 2010 | Jenn-Air JJW8230D Electric Double Oven
My older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
May 24, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JES9860 Electric Kitchen Range Logo
56 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
