Question about RCA HD52W59 HDTV Projection Television
Top of screen is converged corretly bottom of screen isn't
I have a problem with my screen. It just happened after I got a power serge. I tried sdjusting the convergence in the menu screen but it just fixes the middle and top of the screen not the bottom. Also the auto converge doesn't work. It just shows one green square and then just stops and goes back to the menu screen. Is there anyway I could fix this myself? Its been a year and 3 months and I would probably be charged alot to get this fixed I am thinking. Any suggestion would be appreciated. Thanks.
  • 1 more comment
  • Anonymous Jul 19, 2007
    I am not sure but I will check. Really all I need to do is fix the convergence in the service menu and it should be fine. Execept I won't be able to auto converge it.for the reply though.
    Sorry I messed up didn't see that you said electrical storm which is what happened. Thanks for the reply though.
  • Anonymous Jul 28, 2007
    I have another question. I did fix my own problem by going into the service menu. But now everytime I turn on the tv. It shows the welcome screen. I tried turning it off in the service menu but it still doesn't help. Any suggestions? Thanks.
    Sergeant:
  • 274 Answers
The "power surge" you got, was it because of an electrical storm or was it it because a power transformer blew in the neighborhood? I mentioned this only because if it occured due to a power company problem, I'd file a claim with them. They may just pay for your repair. It's worth looking into. Check with a neighbor, they may have had problems too.
Posted on Jul 19, 2007
SOURCE:
There is a concave on the top of the screen and bottom of the screen whenever i try to readjust the convergence i can get 6 out of 8 crosshairs perfect but i cant get the top and bottom due to the concave...
Hello; You have a failed convergence board. JVC does NOT give me ANY info. They won't even talk to me on the phone! On some sets, there is a digital convergence board and a power convergence board that actually drives the convergence yokes on each of the 3 CRT's. If you have both, either one is bad and probably expensive. I recommend people Don't buy JVC products due to their bad reputation. John
Dec 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
Bowed in at top and bottom and colors are separated
You have a convergence issue. First question in customer menu under setup do you have the convergence optioin? IF you DO NOT then chances are you have the fl231 problem. check under my profile in the tips and trick section. IF you do have the option try autoconvergence. if this fails(goes red screen then you might have a convergence power supply problem.
Nov 04, 2008 | RCA D52W19 52" Rear Projection Television
Convergence. shadowing, arch top and bottom, red and green colors
You have a convergence problem. i see these set all the time at shop. first consult the article in tips and tricks section the fl231 fuse problem. it might provide some answer and might turn out to be a simple repair. If you do not have the convergence option under setup in customer menu then i say you have that problem.. otherwise it sounds like a convergence power board issue. if you have the options try autocovergence first and then if that fails try manual convergence of red and blue if the dont move then it will be convergence power board. let me know and ill try to talk you through it
Oct 06, 2008 | RCA HD52W59 HDTV Projection Television
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Convergence
Loss of power supply voltage to run convergence circuit.verify w/service literature.Hands-on technical help needed.
Aug 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Converge problem
Sounds like convergence issue--replace Stk IC's mounted
on large heat sinks. Check power supply for open fuse device.
Re-check convergence alignment.
Aug 11, 2007 | Philips 60PP9352 60" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
115 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
