Question about Kitchen Appliances - Others
On side working good other side doesnt work 2light are working 1 light not working
    Genius:
  • 1,669 Answers
You need to check all the internal wiring on the unit. Grease may have gotten into the wiring and control corcuits.
Posted on Jan 21, 2013
My right brake light doesnt work even though my tail lights do? hazards work fine along with turn signals, why would right light not work when everything else does?
Most of these bulbs have two filaments in side the glass, one for side light, and one for brake light.
Try another KNOWN GOOD bulb, or, swap left to right.
Worst case, its a loom fault or connection.
Apr 02, 2017 | Oldsmobile Cars & Trucks
One of the backup lights on my 2014 Honda Pilot is not working. I replaced it and it is still not working. What could be the problem?
You mean both bulbs are good but 1 side work and the other side is not working...?
-If so then sound's like bad ground on the side that is not work.
Good luck
Mai
Feb 14, 2017 | 2014 Honda Pilot
Why doesnt ac work
Good day.
There can be numerous of problems but let's start at
1 Check the condenser fan
2 Check the evaporator fan
3 Check the pressure switch on high side and low side
4 Check the TX valve
If you checked all these and they all working put your guages on low and high side and let the car on idle speed.
When you switch the ac on, keep your eyes on the guages and record it.
If it's not working then email me back with the readings and I will have a look at it
Thanks from Will
Jun 24, 2014 | 2002 Kia Sedona
Rear lights no Vauxhall Astra not working properly
Good old astra ,i have one a 1.6 GT from 1993 ,a flying machine when my tools are not in the boot and spare battery or two, anyway suspect a fault or dirty earth connection in your case here ,find the comunial earth for the light cluster and run another earth from this wire but leave the old one connected just slice and splice it with a bit of tape and it will all work .
Dec 06, 2012 | Vauxhall Cars & Trucks
My right side turn signal cuircut works but my left side doesnt ive checked the light bulbs but they're all good.
if hazard lights are ok and you can see all are working, you can tell that your signal lever switch is broken.
Nov 18, 2011 | Cars & Trucks
My driver side window wiper works but passage side doesnt and I figure if one works it must not be the motor. I replaced my back lights on passage side and only the break light works but not my turn signal...
If you have only 1 motor controlling your wipers, then something is broken somewhere inside your motor. Since when the motor turns it uses the same gear to move both wipers. Maybe the rod came apart in the motor or broke. Can't say for sure because I don't know your exact set up but 1 motor means you narrowed it down to 1 place. Good luck.
Mar 02, 2011 | 1998 Oldsmobile Cutlass
Window won't roll down, powersteering doesnt work, spedometer doesnt work, ac doesnt work. all this happend when i charged the vehicle
Hopefully all you blew was some fuses. Need to check all fuses under dash & in relay/fuse box underhood. Easiest way, hook up test light to ground & test across all fuses. If blown 1 side of fuse will get power,but not the other side.
Jun 15, 2010 | 1998 Lexus Gs 400
Electrical wiring
You need to revisit the fuse box ,, there may be more than one ! If you think the dashlights fuse are intact , check by switching on/off the side lights while checking the fuse. The fuse beside the side lights fuse should also be a side light fuse. They are handed LH and RH for safety reasons and check you have both side lights in the front. Power locks may be a dash switch /plug connection. Worst case senario ,(temperarily) remove radio and remove any fault you may have introduced into the system . A small bulb type tester will be a great help ! Good luck
Apr 11, 2010 | 2005 GMC Sierra
1st and 2nd light Blinking forever!!!!!
http://www.amazon.com/RCA-DCM315R-30Mbps-Cable-Modem/dp/B00009UI2Z
read it!
Jun 06, 2008 | RCA DCM315R Modem
Kitchen Appliances - Others Logo
178 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
