Question about Maytag MER6772 Gemini Electric Kitchen Range
How do I clear error beeping (F9) on my Amana gas range
I tried to fix my oven door and should not have pressed the clean button. I can not get the "lock"  light to stop blinking and then after so many minutes F9 is displayed and the oven starts beeping,,, Please help :(
  • 318 Answers
Try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Posted on Jan 28, 2009
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
I attempted to hit the self clean button but received a F9 beeping flashing error until I unplugged the range from electricity. How do I stop this F9 error?
Hello & Welcome to FixYa
Error F9 means Latch unlock lower and is displayed due to obstruction in door lock mechanism. If after cleaning the door lock mechanism the problem is still there then replacing the door lock mechanism is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Amana ARGS7650SS Gas Kitchen Range
Oven door locked.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I stared to self clean by Frigidaire FEF355ASE oven. I got the beeping and the F1 note. I pressed clear and then I got beeping and F9. I pressed clear and got F9 again. I tried clearing it again and it...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$%$%
Jul 06, 2009 | Frigidaire FEF352 Electric Kitchen Range
My self cleaning oven door will not open, and keeps beeping and
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I have an Amana glasstop electric stove and i was cleaning it by just wiping it off with a cloth and i think i may have pressed too many buttons at the same time.now my oven door is locked and it was...
F3 Oven temperature sensor or circuit malfunctioning
F9 door lock or lock circuit mal functioning.
Diconnect electrical supply for a couple of minutes.
It should clear. If not contact an authorized service dealer.
Dec 13, 2008 | Amana ACS7270AS Electric Kitchen Range
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
532 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
