Question about Dishwashers
Door on my miele built in dishwasher is broken
I rent an apartment a year ago that came with an old Miele dishwasher G685sc. The spring of the door is broken (I think) and we have to prop it up with a little stool when loading. A service man just left after taking things apart and said the door will always be heavy and it couldn't be fixed. There is hot water coming out of the air vent every time we open the door after a load is finished. He said that to replace the part, it would cost 200+ euros. The conclusion is that we'd better off buying a new but cheaper machine. Is this true? If not, I will try to complain. Thank you in advance for writing back.
  • Dishwashers Master
  • 2,778 Answers
First thing you need to do is SEARCH for "spares"
for your Miele G685sc
We don't seem to have "parts" for your G685sc here
in the USA...
but a casual look over BOSCH hinge and spring costs
show the hinge at $20 USD
AND
SPRING at $10 to $19 US Dollars...
Lower door gasket $20 to $30 USD
AT those prices I would attempt to avoid a "new"
dishwasher... When you are done trying to get a HEATER,
silence and stainless interior...
You are looking at BIG MONEY.
Check the FIT of the door... and health of the gasket(s)....
I'm just saying... I would
(it is the ULTIMATE in recycling).
http://www.appliancepartspros.com/bosch-dishwasher-gasket-seal.html
Posted on Apr 11, 2017
SOURCE: Hygena Dishwasher doesn't fill with water
Hi I have dishwasher,BOSCH SMS 5012 its working evrething ok exept dosen't let water.
I was wondering if there is something I should try before calling out a repair man.
Many thanks in advance
Posted on Feb 27, 2008
SOURCE: Miele G646 dishwasher. This dishwasher
Yes solved by pulling door apart. There is a small drain tube from the bottom of the ventilation vent, which had some blockage.
Cleared it put door back together and now works just like new.
Cheers
Nic
Posted on May 25, 2008
  • 1122 Answers
SOURCE: miele dishwasher racks
first try ebay,you need the model number,or try criagdlist in your area,or repair clinic .com,let me know-mike
Posted on Jun 15, 2008
  • 4 Answers
SOURCE: Miele G868 dishwasher - leaks from front panel air vent
Hi all,
I have had the same problem. Here is what I've done. Take the door apart (a whole bunch of screws on the side of the door). The front panel will come off and you will see a rubber tube. Take it off and blow it out. Then take the blower out (you need to unscrew the inside of the blower). Take apart the blower and clean it out.
Good luck.
Posted on Oct 15, 2008
kachbibi1
  • 979 Answers
SOURCE: Miele G868 Dishwasher is dead, won't even turn on
I had a similar problem. Check the control knob that turns the machine on. At this age, it sounds like the control knob is either bad or a wire has burned off. Check to see if their is an internal fuse in the washer.
Posted on Jan 21, 2009
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
My dishwasher door is falling open. I have to latch it to keep it closed
The spring cables that hold the door have broken so the springs have no effect....
They are not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 11, 2011 | Miele Optima G2470SCVi Built-in Dishwasher
The door on my miele G481 built in dishwasher won't stay open it's really annoying that it keeps popping up when I'm trying to load.
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
May 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele Diamante dishwasher. Rattles when draining.
possibly a piece of broken glass or similar you will have to dismantle pump to remove on the other hand your pump could be worn out and needs replacing either way you will have to check out the pump or put up with the noise
Feb 06, 2010 | Miele 24 in. Novotronic G851SC Plus...
Miele dishwasher racks
Jun 15, 2008 | Dishwashers
Parts
You could buy a no name door seal gasket from any dishwasher parts supplier but you will loose your warranty with Miele. And extended warranties reach up to 6 years if you bought it from a factory authorzed dealer with a factory authorized installion! Call Miele direct. Miele's number is 1-800-843-7231
If you would rather call your local Miele dealer, they'll be more than happy to do help you!
Oct 13, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
