Question about Progressive Computer JSI 6 spkr. Home Theater System with Scan DVD Player, 300W System
Dvd drawer will not open
The jsi dvd player will power up but when you try to open the dvd drawer it wants to open but it doesent . you can turn it off and unplug and whe you turn it back on it does the same thing. it just wont open. help
  • Anonymous Jan 27, 2009
    I have already opened the tray and there was no dvd in it, and the dvd drawer is stuck open now and it wants to go back in, but it will not go in or out. you hit the button and the drawer will move slightly forward and backwards. I NEED HELPPPPP
  • 142 Answers
If that doesn't work, you may have to hit eject and get a little physical, or open the unit.
Posted on Jan 27, 2009
  • 124 Answers
Manually open the tray. It's possible that you have a dvd stuck in the drawer because it wasn't fully seated. Look at at the front of the drive and you will see a tiny hole. Take a paper clip or safety pin, stick it in the hole and push. You will see that the drawer will pop out and you can retrieve your stuck dvd. Thanks for using fixya.com
Why won't the drawer open?
Try this simple answer: on a couple of DVD players I've had, it takes several seconds for the drawer to open. If you press the Open button again during that time, it will close the drawer before it even opens. So try clicking Open once, and then leaving the player alone for a 20 seconds.
Oh, I should have asked first: is the power on? On some players, the power light may be on even if the player is off. Try pressing the power button and see if more lights come on.
Is there a chance that there is a foreign object wedged in there? In my experience, 3-4 years old is prime time for experimenting with DVD players. Have anyone that age in your house? If so, the safe but tedious way to fix that is to remove the case from the DVD player. That usually allows you to see the drawer inside the machine, to see if there's anything in there. The unsafe way involves prying the drawer out; it's unsafe because there is a good chance that you'll destroy the player, and an extremely good chance that you will leave unsightly marks on the front of your player.
Jul 31, 2015 | Televison & Video
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
DVD drawer opening when it shouldn't!
With the price of dvd players and yours bieng 6 years plus it make more sense to just buy a new one.
Jan 10, 2014 | Panasonic SA-PT460
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
JSI dvd player, remote code
I have similar problem, solve it with codes from Koss brand.
Jsi and Koss are made by same lab.
Try Koss codes, it work for me.
good luck!!
Dec 29, 2008 | Progressive Computer JSI 6 spkr. Home...
DVD door won't open
try using a knife without the dvd player plugged in that will get out the cd
Sep 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
320 people viewed this question
Top Progressive Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Progressive Audio Player and Recorder Expert? Answer questions, earn points and help others
