Question about Electrical Supplies
DUNLITE GENERATOR 5 HP HONDA I WANT TO REMOVE ENGINE
I need the owners manual for 7GRBB-377A DUNLITE GENERATOR?
Try Googling (dunlite)(7GRBB-377A)(manual) without parens.
May 29, 2017 | Electrical Supplies
Dunlite dguh2.7s-2 generator. No power when running stopped making power instantly. Engine running sweetly
generator wiring or converter unit fried
needs a generator electrician to fix
Nov 06, 2016 | Electrical Supplies
The Dunlite generator is pre 1986. Where can I find a service manual?
look for a name plate that has name and or model number and either look up dunlite site they are on the web or a small engine repair shop might have the information--paperwork available for you the dunlite company uses different motors to run their generators such as yahama honda and others
Aug 21, 2015 | Cars & Trucks
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda h22 5 speed
stalls. ( ever tune it up,at the 60k service points? )
what year, no year , no joy, 1978 to 2001 , lots huh?
and what engine option, displacement (size)
over 10 engines
Third-generation Honda Prelude engines:
B20A/B20A1 - 2.0L DOHC PGM-FI 143/160 hp (Japan/Europe)
B20A3 - 2.0L SOHC 12v carb 104 hp North America
B20A4 - 2.0L SOHC 12v carb Global, except North America
B20A5 - 2.0L DOHC PGM-FI 135 hp (101 kW) North America
B20A6 - 2.0L DOHC PGM-FI 142 hp (106 kW) Oceania
B20A7 - 2.0L DOHC PGM-FI 150 hp (110 kW) Europe
B20A8 - 2.0L DOHC PGM-FI 133 hp (99 kW) Europe
B20A9 - 2.0L DOHC PGM-FI 140 hp (100 kW) Europe
B21A - 2.1L DOHC PGM-FI 145 hp (108 kW) Japan (SI States)
B21A1 - 2.1L DOHC PGM-FI 140 hp (100 kW) North America
Jan 11, 2014 | Honda Prelude Cars & Trucks
Can i buy a remote throttle cable to fit and bolt right on to the motor of a honda gxv390.
if its a generator No because the engine needs to be set at 3000 rpm constant or it will damage what ever its running
Nov 03, 2013 | Honda Vertical Engine 13 HP OHV ES 1 x...
How to remove generator from engine (model DGUH5S-2). 11 horsepower Honda engine.GX340 .
I have not worked on Dunlite generators, however have worked on many different brands using the GX340. When removing generator parts, one must keep in mind the brushes contacting the armature. Remove brush pack if any and set to side. Next unplug stator wiring making sure to draw diagram of connections. Remove bolts mounting generator/stator housing to frame and carefuflly pull off leaving only armature /rotor on the crank of the engine. Remove the long bolt thru rotor into crank. Now you will need to apply penetrating oil to the shaft of the engine to loosen the rust on the taper. It may take several applications. Place a piece of hardwood against
metal to protect the rotor and firmly rap with hammer on
both sides. You may need to use pry bar against engine
and rotor as you hammer hardwood. Repeat as necessary,
some rotors will be very stuck due to rust. Be very
carefull with hammer and or prybars not to damage
windings. Have patience and let oil work. Good luck.
Jan 28, 2011 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
