Question about HP Compaq 610 T5870 156 WH248UTABA (WH248UTABA) PC Desktop
Compaq 610 windows 7 is unable to detect network
Previously iam able to cinnect to internet through my mobile blutooth,usb and wifi but now whats wrong iam not getting iam not able to connect to internet
  • HP Master
  • 27,725 Answers
Click on the "Start" menu and selecting "Control Panel."Click on the icon that reads "hardware and Sound." Then, select the tab that reads "Bluetooth Devices." Click on the "Add" button. This will put your computer in "Search Mode." This means that it will search for any compatible Bluetooth devices in the area. Put your Bluetooth device in "Discovery Mode." This can be done by pressing and holding the button on the side of the device. This will cause the device to send out a signal that will be received by the laptop computer.
Select your device from the list of found devices on your laptop. Once this is done, your laptop and Bluetooth device will be permanently connected as long as they are both turned on.
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system Hope this helps. b>
Posted on Jan 21, 2013
4 Suggested Answers
map9966
  • 2351 Answers
SOURCE: compaq sr1950nx internet connect
Hi mp295,
Well click this link to Compaq Presario SR1950NX for software & Driver downloads. Pick you operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=3184153&
Good Luck & kind Regards
Posted on Mar 02, 2008
  • 4 Answers
SOURCE: Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Posted on Mar 23, 2009
  • 108 Answers
SOURCE: cannot connect to internet
use system restore and restore it to earlier date when it was working perfectly
Posted on Jul 22, 2009
How do i get internet connections?
Richards, Smartphone How to connect to the internet, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Your SmartPhone to Internet Only Using WiFi
How to access the internet on smartphone
How to Connect Your Android to Your PCs Internet Connection Over USB
Aug 09, 2016 | Nokia Lumia 630 8GB Unlocked GSM Windows...
Comapq 510 crashes in win 7
carefuully and quckly wach you compuer when it boots and press the right f something key i have a hard tiem doing this too there less then a 2 second window
its gonna say a coupla options befor it acutaly starts loading the win 7, so you gotta be on your toes,
i dont dont remember what 7 says cause me and my 7 have how shall it aherm eparted im back on good ol xp
so any ways it's imperitive that you press the on that getts you to bios
normall you you just dont mess with bios but sometimes you simply must now is one of those times alls you ahve to do is put the lan wifi switch on in bios and violins you is up and runnin on the internets in no time fliat
bye bye
michet@aol,com
Jun 15, 2013 | Compaq DECbridge 510 (defebad)
Iam not able to connect my internet connection in my pc by my mobile..iam using motorocker e6 mobile & using windows 7
Use motorola phone tools and connect your phone with the data cable.enter the network privider's phone number and then connect to internet.
Mar 20, 2011 | Motorola Mobility ROKR E6 Smartphone
I am trying install winodws7 on HP Compaq 610 having ATI Radeon Catalyst(Current OS winXP Pro SP2). But in the installation window it is showing the CD/DVD driver missing message. So, googled it and found...
Hie there i have installed and reinstall Win 7 Ultimate on Multiple Compaq 610's without any problem.
i once encountered a prob like this one but was lazy so i removed my Hdd and formatted it elsewhere and Walaa my prob was gone. i didn't have to upgrade or downgrade my bios and am still using the same laptop 2day. Just make sure you DVD rom aint damaged.
good luck
Aug 06, 2010 | HP Compaq 610 T5870 156 WH248UTABA...
I cant connect to the internet
first you have to make sure if what connection you want to use, if its wifi or a network cable, and make sure you properly set up your connections, on your control panel you can choose my network place or a wireless connection wizard. If your are using its wifi make sure to click the button that activate the its wifi.
Apr 26, 2010 | HP Compaq 610 T5870 156 WH248UTABA...
I have compaq 610 laptop. my inbuilt webcam isnt working on vista. i got drivers from hp site and installed and yet not working. pls, need help
i am using windows 7 in my laptop compaq610 model webcam device is already installed but it is not networking.is any software to be used or what?
Nov 01, 2009 | Computers & Internet
Compaq evo n610c wireless lan w200 - is network card internal? or do i need to purchase a card to get my computer to work at a wi-fi location...i need to know what i have to do to get internet at other...
The EVO 610 has a built-in modem and a network LAN but no wireless LAN.
If you wish to connect to the Internet at home and elsewhere you have a few options.
You can use a PCMCIA wireless network card or a USB wireless device. These devices will allow you to connect to WiFi places such as Internet cafes or free WiFi locations such as McDonalads, Starbucks and airports etc.
OR
You can use an Internet Service Provider that provides country and or state wide roaming access, and they usually use wireless netword cards that integrate with the mobile (G3) network.
You need to check with various Internet Service Providers to see what they offer, the various plans, costs and also if they offer roaming access.
Be aware that connecting to public WiFi networks can have security issues if you are not protected.
May 18, 2009 | Compaq Evo N610C Notebook
Connect the lg mobile to pc
HAI,TO CONNECT INTERNET THROUGH CABLE OR BLUTOOTH.
(i) 1.CABLE : INSTAL DRIVERS FOR THE CABLE AND LG PC SUITE,RESTART PC THEN CONNECT DATA CABLE BEDWEEN PC AND MOBILE.IT,S ORIGINAL CABLE DRIVERS ARE AUTOMATICALY INSTALED,ORDINARY CABLE MANUALLY INSTAL DRIVERS.
2.THEN FOLLOW TO CONNECT INTERNET:
   START>CONTROL PANNEL>SELECT NETWORK     CONNECTIONS>SELECT CREATE NEW CONNECTION>FINISH.RESTART PC AND THEN CONNECT INTERNET THROUGH NEW CREATED IN NETWORK CONNECTIONS.
(ii)VIA 1.BLUTOOTH:INSTAL BLUTOOTH SOAFTWARE(BLUE SOLI) AND RESTART PC.
2.ON BLUTOOTH ON MOBILE AND CONNECT MOBILE TO PC (BLUESOLI).SELECT DUN INTERNET CONNECTION TO INTERNET.
Jun 30, 2008 | Computers & Internet
Compaq nX 7400 Bluetooth device not detected by the system and modem drivers not detected
you gotta love vista..did you check nokia's site for the vista 64 bit driver? If you find it post it here, and we'll let the world know about it
Mar 21, 2008 | Computers & Internet
HP Compaq 610 T5870 156  WH248UTABA (WH248UTABA) PC Desktop Logo
66 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
