Question about Siemens Gigaset 4015 Cordless Phone
Siemens gigaset as140 registering handset troubleshooting
For some reason i cant register the one handset - please help
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 107 Answers
SOURCE: Registering a Gigaset AL185 handset
i couldnt find a link to your owners manual, but, if you go into the menu in your phone and scroll down to "register handset" that should work
Posted on Jun 21, 2009
SOURCE: Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
Posted on Mar 06, 2010
SOURCE: i cant register my second in pair gigaset A160
Read the manual, page 2.
Posted on Feb 10, 2011
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
Keeps going back to Register HS
Thats because there are too many handsets registered to base OR it can't find the base. Did you set it to register then pressed the little tab in on the bottom of the base? You have to hold tab down and keep phone close to base (a foot or so). If handset goes out of reg mode, you have to put it back in, then quickly press base tab down again before it stops.
Dec 17, 2009 | Siemens Gigaset A140 Cordless Phone
Jun 21, 2009 | Siemens Gigaset 4215 Cordless Phone
Handset won't work
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
My siemens 4010 cordless phone is saying "Base Search" recently
"Base Search" will display for several reasons.
  1. The base station is turned off or not working properly.
  2. The handset is not registered.
  3. The handset may be registered somewhere else, de-register it.
  4. The units (both base and handset/s) may need to be reset to factory default.
You may have already tried this.
Jan 15, 2009 | Siemens Gigaset 4010 Cordless Phone
I have a siemens gigaset S455 i had to take the phone to a new house that im going to rent next month to find out the new phone number back home i need to register the handsets (x2) and cant find the...
unplug the base and press the register button. (it's the round one to the left of the minus button) holding the register button plug the base in and continue to hold the register button for at least two seconds. you should hear a beep. the pin has been reset to 0000.
Dec 07, 2008 | Siemens Gigaset S455 Cordless Phone
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
System pin unknown
I will email you steps to restore factory default PIN...send me a note
Nov 20, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 4015 Cordless Phone Logo
54 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
