Purchased used dayton (m) 32433e243 / 36c13 / t 306 / & was told was running on propane. hooked up & get black smoke. had 10lb & then .5lb regulators. installed the .5lb & still black smoke. tag does say LP? Thanks Steve
    Guru:
  • 462 Answers
Look at the orfices on the manifold if these are correct sized then if it has a smokey outlet you'll have to get all the byproducts of non burned gas out of the heat exchanger before it will stop ALSO this BLACK SOOT IS FLAMABLE. It can burn when hot enoug with enough O2 getting to it. Inspect the combustion air (if so equiped) on the burner manifold adjust to allow MORE air into the orfice but 1st disassemble and clean the whole thing. YES it will be messy from my expierance but its for safety and to complete the repairs. Take the model number, BTU rating, one of the orfices and number of burners with you to a QUALITY LPGAS Supplier. they can help you decide if these are the correct size and may be able to make more advice available. Ask about setting the combustion air to clarify what I said above.
Please grade me accordigly and if I need to be more preciceI need more information from you. THANK YOU AND GOOD LUCK.
Posted on Mar 02, 2009
Is there a way to calibrate without 3-50 pound weights?
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Jul 25, 2015 | Office Equipment & Supplies
For the Health-o-meter physician's beam scale, how do you know when it is in balance? What should you do to get it in balance?
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
Dec 27, 2010 | Health-O-Meter Health o meter 402KLWH...
My dayton 375000 torpedo keep freezing the propane tank. What can I do to stop it?
You are drawing gas too fast for the tank to vaporize. You either need to hook the heater to a larger tank, warm your existing tank or tie two tanks together and keep one tank empty.
Feb 07, 2010 | Dayton Heating & Cooling
Parts are missing for The Impex Powerhouse
Wore out and the maufacturer cannot replace a tech rod unit for an impex TR-2 home gym.Need complete unit of 2-50lb,2-25lb,4-10lb,2-5lb rods on a plastic base.Can anyone help?
Feb 06, 2010 | Exercise & Fitness
I have a dayton heater, older model, I just recently hooked it up and it is blowing a ton of black smoke, I wouldnt think propane would do this, is it normal? Is there a problem?
Hi, this will happen for sure with propane heaters. They are notorious for getting carboned up.It Happens a lot on central heat and air units if the gas pressure at the main gas valve is not adjusted properly on the outlet side of the valve in inches of water column.It takes 3.4"of w.c.for natural gas and used to be around 13.0"w.c.for propane.What you will have to do is to clean this unit inside until you can remove as much carbon as you can. You say it is a older model, so i would say that it has taken a long time for this to build up. I have seen new propane package units carbon up with in a week of being started due to a gas valve not set properly. I dont believe you will have to adjust you'res, just a good cleaning should take care of the problem. All fuel lines ,orfices, and where ever you see carbon build up.It can get to be a mess and I would where a dust mask also.
Good Luck.
Shastalaker7
Nov 06, 2009 | Dayton G73 Utility Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Gas flow problem...
Stick with the one pound disposable propane bottles & you will be fine. The 5lb tank is not compatable.
Jul 01, 2009 | Weber Q Grill
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
