Question about Kustom Music
Kustom kpc15m No sound from subwoofer and very distorted sound from tweeter horn
Kustom KPM8420T schematic
Where can I find a schematic for a Kustom KPM8420T?
Jul 07, 2013 | Music
I have got a kustom KPC10mp and i am trying to hook it up to a kustom non- powered and i cant get no sound thru the monitor , Can this be done .The line out dont make no sound when it is connected to the...
In a word, NO. The line out is line level audio... it has NO power amp and cannot drive a non-powered speaker. I have both of these cabinets myself. You need to use an amp with the non-powered speaker. When using an external amp you will need to make sure you phase the two speakers correctely... you could just reverse the speaker leads of the non-powered one if needed.
Sep 11, 2011 | Kustom KPC10MP 10" Powered Monitor Speaker
Rattle/vibration in the horn of my 4x10 cabinet
Open cabinet and look for loose wiring. You may have blown the tweeter horn if nothing is loose.
Aug 25, 2011 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
Kustom KPM7250T mixer made a loud popping noise and lost sound to speakers during gig, but front power lights stayed on. Accessible fuse good. have it at dealer to see if can be repaired but he needs...
Pilot lights mean very little. Either a filter capacitor failed or other part(s) failed. Needs to go to the repair shop. The damage MAY be visible or require test equipment to diagnose.
Aug 11, 2011 | Kustom KPM7250T PA Amplifier/Mixer
My Kustom HV100 amplifier turns on but takes forever to make sound. When it finally works it stays on the rest of the night. How do I fix this?
if you have replaced the preamp tube than try looking at the capictor. i had just bought one and i thought the tube was out turned out i was worng
Jun 07, 2011 | Kustom High Voltage Hybrid HV100 Guitar...
My monitor is styill for working but the tweeter dont make any sound. i think its blowed up, is there a fuse a something that could be replaced in the amp?
no fuse in there unfortunately.
The problem could either be a blown tweeter (but that would likely cause distortion rather than silence) or a fault with the amp or crossover. Often it seems a relay is at fault in these instances with dynaudio monitors. In any case, unless you have considerable electronics knowledge (which I think it's fair to assume you don't ?) you won't be able to fix em yourself. Give dynaudio an email or call - they're helpful.
Dynaudio North America
1140 Tower Lane
Bensenville, Illinois 60106
USA
Phone (630) 238-4200
Fax (630) 238-0112
For Service: service@dynaudiousa.com
Apr 25, 2011 | Dynaudio BM5A MKII Monitor Studio Active
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
Music Logo
Top Kustom Music Experts
Michial Gueffroy
Are you a Kustom Music Expert? Answer questions, earn points and help others
