Question about Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer
Dryer door won't shut
The metal catch for the door is loose and won't engage the stud to shut the door completely. I'm having trouble removing the metal catch.
  • James Metcalfe
    James Metcalfe Jan 27, 2009
    It won't line up because it is loose and I can't secure it.
  • 142 Answers
You will have to adjust the catch to line up and secure it ,
good luck !
Posted on Jan 27, 2009
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Maytag Model MGD6400TQ Front Door Won't Shut Completely
heres the aprt number for the "catch" , if you have a problem removing it i would simply push it into the door, it will fall to teh bottom , no need to worry about ti wont hurt nothin.. its meant to grab and snap into place as you push it into place, whichis why itdoesnt wnat to pull back out the same way W10111905
Zanussi dryer tc7114W door shuts blows the fuse
Behind the door locking mechanism is a switch, it sounds like from the force a wire might be touching the inside of the machine chassis. Gain access to the back of this switch and check there are not loose cables or cables touching metal.
You should be able to access it by removing the top of the machine, remove the 3 screws and tap the front of the lid with the but of you hand to knock it back and remove it. With a torch look down the inside from of the machine to idenfiy anything loose. Alternativly remove the back of the machine and see of you can see it that way, as that model does have quite a large back access panel.
Keep your screws safe ;)
Oct 03, 2012 | Zanussi TC7114W Electric Dryer
Door will not stay shut...........simply pops open after 10 or 15 seconds. No visible damage. No debris along the door pathway. Perhaps a new plastic latch. The old one looks fine.
You just need to replace the catch and the strike it is easy to install.
Detailed Viewhttp://www.easyapplianceparts.com/PartInfo.aspx?Inventory=334230&SourceCode=6 EAP334230: Door Catch Kit This dryer door latch kit comes with one plastic door latch, and one metal door strike.
Easy Part #: EAP334230 Compare At: $4.75 Your Price: $3.96 You save: $.79 Availability: In Stock 334230_1_m.jpg
Above example contains part: EAP334230.
Click image to see large version
Model number:
Part description in this model:
Part location: #
Series number: -->
334230_1_s.jpg 334230_2_s.jpg 334230_3_s.jpg function KeyPress(e) { if(e.keyCode == '13') { if(document.getElementById('_ctl0_menu1_SearchNum').value != "") { document.getElementById('_ctl0_menu1_SearchButton').focus(); } else { e.returnValue=false; //required for IE if(e.preventDefault) { e.preventDefault(); } // required for gecko } } } '); //-->
Dec 03, 2010 | Kenmore 62602 Electric Dryer
I have a Kenmore 500 that shuts off if the load touches the door from the inside or wont start unless I press the door in again after its shut. I'm assuming there is a safety switch the door touches to let...
sounds like the door catch is loose,this is what holds the door shut,when the clothes are spinning they hit the door opening it enough to reset the door switch,there's a metal or plastic tab that goes into the catch,easy to install and part is cheap money
Oct 13, 2010 | Kenmore 500 6952 Dryer
Seems to be ppower, cheched fuses where the box
this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Nov 04, 2009 | Maytag MDE2600 Electric Dryer
Suddenly stopped working will not start at all any setting
assuming that the circuit breaker or fuse is not blown, this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Nov 02, 2009 | Kenmore 62802 Electric Dryer
Kenmore Electric dryer Model 110.8708 - brand new, worked fine for 2 days. Now suddenly the dryer door pops open on its own and shuts down the dryer. Is this an adjustment ?
Sounds like the door catch is weak. You can try to spead the prongs on the dryer catch (the metal protusion on the dryer, not the door), but be careful. Unless it's very easy to do, call the wrranty dealer for the the machine since it should still be under warranty and the catch should be replaced at no cost to you.
Apr 12, 2009 | Kenmore Dryers
Jan 27, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Machine suddenly stopped working says the door is open when it is shut
Hiya .. Is there a metal hinge catch on the washer, where the door catch closes to? If there is.. its either loose, or the catch on the door itself is loose, which is normally made of plastic, tighten these up, see if this eleiminates your prob
Regards faggly
Mar 23, 2008 | Washing Machines
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
468 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
