Question about Nintendo Wii Fit for Wii
Re chargable battery pack not working
I have the rechargable battery pack in my wii fit board. The power keeps cutting out, and the error message says communication lost, please turn power back on.  This happens over and over again.  The battery pack is newly charged, and has never been used. I never had this problem when I used regular batteries in the past.
  • wayne618 Jan 27, 2009
    didnt really help
  • 19,396 Answers
Often you get troubles with the battery pack connector, check that the battery pack is holding connection to the Wii.
If the battery pack is well installed , and also loses connection when the Wii is staying steady and not in use, then the battery pack is defective.
If I was in your shooes I would go to the retailer and ask a replacement.
Posted on Jan 27, 2009
  • 565 Answers
The battery of your wii fit is with deect go change it in service
  • Teet Bergmann Jan 27, 2009
    Installing the Batteries
      Important Note:
      If you would like to use rechargeable batteries, the only type of
      battery recommended are Nickel Metal Hydride batteries. When it comes
      to using rechargeable batteries, you must follow manufacturer
      guidelines for safety and proper usage. Failure to do so could cause
      damage to the Wii Remote and void the warranty.
    1. Remove the battery cover on the bottom of the Wii Balance Board and insert four AA batteries according to the diagram.
    2. Be
      sure to insert the negative(-) end first when inserting new batteries,
      and remove the positive (+) end first when replacing the batteries.
    Placing the Wii Balance Board properly
    1. Place the Wii Balance Board directly in front of the TV with the Power Button (blue light) facing away from the TV.
    2. Make sure that the Wii Remote can be used within 3 to 10 feet of the sensor bar when standing on the Wii Balance Board.
    3. Ensure there is adequate space between the player and any objects or people (at least 3 feet).
    4. Make sure the board is on a stable, flat, horizontal surface. Avoid slippery surfaces.
    5. Verify
      that the balance sensors are in direct contact with the floor. If
      carpet or other material comes in contact with the bottom of the board,
      install the foot extensions.
    Sergeant:
  • 221 Answers
Its not actually a battery problem according to me.have found this issue many a times its actually happening because the system just gets hanged.just check the nintendo system board for this issue
    Sergeant:
    Novelist:
  • 326 Answers
May be the batteries are not supporting the unit as there may be some loose connections or internal battery fault.
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
How do I charge the wii fit board?
A Wii balance board is not a re-chargable piece of hardware... it's battery powered. You can buy re-chargable battaries and recharge them every time your power runs out (if you really want re-charge capability). Otherwise you can just buy new batteries and replace the old ones when you run out of power.
Mar 28, 2010 | Nintendo Wii Fit for Wii
I had been using my Wii fit without any problems until I got (1) a rechargeable battery pack and (2) Wii fit plus. Since then, I don't get very far until the blue light on the balance board starts flashing...
the rechargeable batteries have a rating system, for how long they last.
a battery with 850mHa will last a far shorter time than 1 with 2500mHa rating.
and non rechargeable batteries have a much loger life span than all rechargeables.
Also rechargeables are 1.2 volt instead of 1.5 volt and will aleays run down alot quicker.
Feb 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
Ever since buying a "re-Chargable" battery pak for Wii Fit it takes off more weight than should be (approx 3.7KG more). The Wii Fit has been working great up until the Battery pak. Strange thing is,
If you're using the Wii Fit on carpet, you need to use the additional legs that came in the package. Simple pop 'em on and they should (hopefully) fix the problem.
May 24, 2009 | Nintendo Wii Fit for Wii
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
Problem with wii fit rechargeable battery pack
make sure the battery charger is connected, and that the port connections are tight, other than that I would say you have a faulty charger.
Feb 06, 2009 | Nintendo Fit Battery Pack for Wii
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
I have the rechargeable battery pack on in my wii fit balance board. I the power keeps cutting out and it is saying communication is lost on the balance board, and to push the power button again. This...
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Jan 27, 2009 | Nintendo Wii Fit for Wii
Wii fit board rechargable battery pack
Have you tried regular batteries, the UK model takes 4 AA batteries or is the US model different? Cheap third party battery packs made in China are rubbish and never work for long if at all.
Aug 14, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
