Question about LG Computers & Internet
I have an LG IPS lcd led monitor, IPS224-PN, the problem is it keeps flickering like an old tv set that had static due to a bad arial. Any suggestions? thank you!
LG IPS LCD LED monitor, IPS224-PN
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
  • 14 Answers
SOURCE: BenQ LCD Monitor FP567, no display.The Green Led
dreaded inverter board problem..here is a tip on where to look inside your lcd as is similar models...http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Posted on Mar 03, 2009
  • 31 Answers
SOURCE: Viewsoniv VA 902 LCD 19" monitor
If the signal cable is detachable from the monitor, you could try with another cable... Regarding the power, I' not an expert, but if you're familiar with electronics basics, like risks of high voltage, soldering, etc, and you'd like to experiment with the unit, then I can give you some hints.
Posted on Mar 20, 2009
anjana03
  • 361 Answers
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Posted on Jun 15, 2009
  • 6771 Answers
SOURCE: Samsung SyncMaster 740N 17" LCD
The problem is in the power supply and inverter board, cause normally bad capacitors that sometimes bulge at the top indicating they are open.
Posted on Feb 21, 2011
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
The tv suddenly goes black and the power light blinks red
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
LG Flatron IPS231B-BN 23 LED LCD Monitor - 169 - 5 ms. 23IN WS IPS LED LCD
What is the problem you faces with this TV? Provide more details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 31, 2014 | LG Televison & Video
I need lg flatron ips234 led datasheet
you can get a manual here
http://www.lg.com/uk/support-product/lg-IPS234V
or here
http://www.manualslib.com/manual/415946/Lg-Ips224v.html?page=12#manual
May 31, 2014 | LG Flatron IPS231B-BN 23 LED LCD Monitor -...
Hi i have a lg tv and it keeps turning on and off what can i do to fix it
- Flickering screen
- Dim screen
- Slow start
May 12, 2014 | Televison & Video
When I turn on my Vizio, the picture is "squished" and the bottom 1/3rd of the screen is white static. The TV is only 6 months old.
- Flickering screen
- Dim screen
- Slow start
Apr 22, 2014 | Vizio Televison & Video
Lg42 578v no picture
- Flickering screen
- Dim screen
- Slow start
Apr 12, 2014 | LG Televison & Video
Viewsonic 5230p video black banding with blue and then will clear up
- Flickering screen
- Dim screen
- Slow start
Apr 03, 2014 | Panasonic 37" VIERA Full HD 1080p IPS LED...
One side darker that other
the cause is either the back light get busted or connectors get worn out. but since it is a brand new you can avail the warranty just send it back to the supplier for check up.
Mar 24, 2013 | LG IPS226V-PN Flatron Widescreen LCD...
Computers & Internet Logo
140 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
