Question about LG RU-17LZ50C 17 in. HDTV-Ready LCD Television
Flat panel Tv will not turn on
I have a Magnavox 17md255v 17 in Lcd Tv/Dvd Combo and i have power to my ac\adapter (green light is on) but no power to unit. i have had this for about a year already.
5 Suggested Answers
  • 83 Answers
SOURCE: Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Posted on Jan 25, 2009
  • 8457 Answers
Ur power supply board is dead,must be replaced.
Posted on Nov 03, 2009
  • 181 Answers
SOURCE: having trouble inserting dvd into LCD TV/DVD combo
looks like your dvd unit has a problem. don't force the disc into! time to surrender to expert tech. this is not do it yourself project, sorry!
you may check with, parts distributor for complete dvd assy.
good luck!
Alex's tv.
Posted on Feb 03, 2010
  • 8457 Answers
SOURCE: lg tv takes a long time to turn on. Flat panel 32"
Power supply board have those parts call capacitors are dying,have leakages gases capacitors parts.Take the tv aparts.The power supply board,that the board,where the power a/c cord plug into it.U know basic electronic,have all the tools?know basic soldering?Searches the power supply board for those dying capacitors,that have leakages of gases going to dead capacitors.These dying capacitors on the power supply board alway bulges up on it tops or puffing up on it tops.These dying capacitors,must be replaced.The tv power will power up as normal and faster.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Posted on Aug 04, 2010
  • 295 Answers
SOURCE: DVD disc stuck in built
1. Power the set down.
2. Hold the eject button on the drive while you plug it back in and power it back up.
That should eject the drive.
Posted on Aug 29, 2011
0 characters
1 Points
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ... > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Flat Panel Televisions
Where is cable hook up located on back of tv
silver threaded cylinder, about one quarter inch around.....this is called an "f" connector
Jun 07, 2014 | Magnavox 17md255v/17
Cap checker bad
fault in main controlling board
Nov 19, 2013 | Philips Magnavox 26MD357B-37 26 in. LCD...
Www sunaiservice com
Main board is faulty. Should be replaced.
Apr 30, 2013 | Philips Magnavox 26MD357B-37 26 in. LCD...
Will not power on
replace the power supply board Available at
Jan 21, 2013 | Philips Magnavox 26MD357B-37 26 in. LCD...
Power light is on (Red & Green) but no picture
this like your tv at stanby mode, turn on with remote control, if no effect this mean you must contact service center
Jan 18, 2011 | Philips Magnavox 26MD357B-37 26 in. LCD...
Lost my ac/dc adapter
Go to the philips-magnavox-funai web site:
Use the 800 number ... tom
Apr 16, 2010 | AOMNI Corporation Magnavox 15MF605T/17 15...
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
LG RU-17LZ50C 17 in. HDTV-Ready LCD Television Logo
104 people viewed this question
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
