Question about Panasonic Coffee Makers & Espresso Machines
Leaking jug on Panasonic NC-ZF1 coffee maker
When pouring coffee, it leaks from the sealed plastic top of the jug, not from the spout !
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
SOURCE: My Bunn coffee maker is leaking water
  1. Remove nut and gaskets
  2. Mix small batch of JB Quick (a version of JB Weld)
  3. Spread JB Quick with putty knofe or wide screw driver on bottom and top of degraded plastic around hole
  4. Let dry foe four or five hours (speed us slightly with hair dryer)
  5. Smoothe hard but uneven surface with fine sandpaper
  6. Reassemble
Posted on Oct 28, 2008
SOURCE: coffee maker leaking from bottom
There is a hole that goes though the bottom of the water chamber side.
The unit will not leak when there is water in the water chamber. The only reason for water to come out the hole is condensation from making the water. There are no hoses in the water chamber area.
Posted on Jan 01, 2009
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
Cuisinexpert
  • 61 Answers
SOURCE: water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Posted on Aug 27, 2009
Coffee dripping out of spouts instead of pouring.
You have not included the make and model of the coffee maker.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 15, 2014 | Coffee Makers & Espresso Machines
My jura en9 pour spout clogged. How do I disassemble to clean out blockage? It is pour very slow and coffee is leaking out the sides of the spout.
Hi Eric
Can you get a pipe cleaner up the spout and clean?
Otherwise.... Take some photos and start unclipping & unscrewing
Thats how I replaced the Element in mine.
Check YouTube
Nov 08, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My 33600 leaks were the cup indicater meets the spout, can it be tightened or is there an o-ring that can be replaced? Tony @ Arizona Party Rental
There is an o-ring that is in there to seal keep the seal between the spout and the level. However, that seal is not available as an individual piece from West Bend. The spout and level come complete as one unit.
Oct 28, 2010 | West Bend 33600 Coffee Maker
The plastic top of the glass pot on two coffee makers drip.
This is a design flaw and can be corrected by enlarging the lid spout. First remove the plastic lid. Then use a fine grinder or sandpaper to remove approximately 1/8 inch of plastic from the lid spout. Follow the exact same contour of the oval spout. However, do not take off so much material that you disturb the small plastic tabs that hold the lid to the pot. Finish by slightly rounding the edges where the material was removed with fine sandpaper. No leaks - no drips.
Apr 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Leaking Coffeepot
I have the same leaking problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
Jan 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Jan 12, 2009 | Bunn VPR Coffee Maker
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Lid on carafe
Sadly, I have about 10 people who have this coffee maker. It is a wonderful little coffee maker and is very delicate.
the worst problem all the people here say is the lid leaks like a waterfall or it leaks by dripping non stop while pouring.
I had to call Bunn, who made this machine, and they have yet to figure out a solution to this problem other than having people who own this machine buy a whole new carafe with new seals.
You might try your local applianace repair store. Sometimes their engineers are smart guys who knows exactly what seals will work or where to get the parts you need better than the actual manufacter.
May 12, 2008 | Bunn BT10B Coffee Maker
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
Coffee Makers & Espresso Machines Logo
81 people viewed this question
Top Panasonic Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Panasonic Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
