Question about Cell Phones
How do I connect Nuvelli Bluetooth Sound Cylinder to my phone? I scan for Bluetooth Devices but nothing shows up on my phone. I'd appreciate your help. Thanks
How to connect motorola h350 bluetooth device for listen the music in our android phone
Go to Settings on your phone turn on device as you start your Bluetooth on your phone. They should find each other and pair automatically but if they don't, turn off the device and then on again then immediately touch "scan" on your Bluetooth setting on your phone. If a new device shows up after scanning under "available devices" touch the new device name and it should pair. Good luck!
Aug 05, 2017 | Motorola Radio Communications
How to connect Nokia 0979 bluetooth to Samsung note3 phone. In this bluetooth there is no volume control swith.
Hi . Make sure that both of the devices have bluetooth turned on. An be visable On any of them press scan and the other should show up in the area .click on the phone you just scanned and there should be a option to type in a code no. Then on other do the same and type in a code of 4 digits and put the same code in the second device and press connect
I hope that this helps
Dec 14, 2014 | Cell Phones
My phone cant find my kindle on Bluetooth.both switched on but phone keeps failing to send
Turn off both devices bluetooth. Turn them both back on and then do a scan on both sides it should pair up.
A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
Nov 22, 2014 | Tablets & eReaders
How do I connect phone to plantronics
hi June,
I assume you are using a Plantronics wireless headphone? ensure your phone is on and Bluetooth is switched on in your phone settings.
hold the button on the headphone until the light starts flashing, if this does not happen ensure the headphone is charged. in Bluetooth options on your phone ensure your phone is set to "can be seen by other devices" and then use "scan devices" to find your headphone, if you see Plantronics in the list select it and press "pairing" this will then connect the headset to the phone. once paired, everytime your headset is on and Bluetooth is on, you need to just press the button on the headset and it will automatically connect to your phone.(as long as the headset name is not deleted from the Bluetooth list)
If your phone does not show in the headset in the Bluetooth list, keep the phone scanning and press the button on the headset to start the light flashing this is now causing the headset to search for the phone. once the headset shows in the phone list do as above.
I hope this was useful.
Nov 03, 2014 | Plantronics Audio Players & Recorders
Bluetooth connection failure between a Droid X and Nakamichi Bluetooth headphones
follow some solotions
1. make visible bluetooth
2. delete some paired devices then pair your device
Nov 20, 2013 | Radio Communications
I can't connect my Emerson Wireless Bluetooth to my Android Phone. Every time I press "Scan for devices". Nothing pops/shows up. I don't know how to get the Bluetooth to connect to the Android Phone. How...
with the bluetooth on, hold down the round button for about 8 to 10 seconds and the light will start to flash red and blue. That means the headset is in pairing mode. The pass key should be 0000 or 1234.
let me know if that works!
Thanks
Oct 29, 2013 | Emerson EM227 Bluetooth Headset
Cs southerntelecom com
I don't know how to connect the Emerson Wireless Bluetooth to my Android Phone. How do I get the bluetooth to show up when I click on "Scan for devices". How do I get the bluetooth to show up?
Oct 04, 2013 | Tablets & eReaders
I dont know how to able the bluetooth of blackberry curve 8520??
Here are the pairing instructions for the Discovery 610 to your mobile device.
Bluetooth Pairing Instructions:
Look in your mobile phones manual for the section that describes how to set up a Bluetooth wireless connection.
1. Move through the menu selections on your phone until the phone display shows "Look for Devices," or equivalent, as a selection.
2. With your headset turned off, hold down the call control button until the headset status indicator briefly glows blue, then flashes red and blue. The headset is now in discovery mode and will stay that way for 30 seconds.
3. On your phone, highlight and select "Look for Devices", or equivalent, to activate the scan for the headset.
4. When the phone display shows the scan results, select "6xx Plantronics". The phone will continue to search for the headset.
5. When the phone display asks for a passkey, type "0000" and press Enter.
Your headset is now linked to your phone.
I hope this helps.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics Bluetooth Headset 610 Wireless...
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
My stereo system is showing HF error 68 and will not connect to my mobile phone. The system is a KDC BT50U
This error has nothing to do with installation - there is a bluetooth compatibility issue.
Not all bluetooth devices are compatible, and some only have limited functionality.
If you have already reset the unit, and the problem persists - the phone you are pairing is not compatible with the radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 12, 2010 | Kenwood Car Audio & Video
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
