I live in Malawi. Have Fuzzy Machine old model with controls in line on top of machine panel. It is not spinning correctly, have checked all the pipes, nothing in them. It washes and pump is working well. Just the spinning, It pumps out the water, starts the first cycle of spin, stops to start the second cycle of spin, doesn't doeit. What is wrong?
  • Washing Mach... Master
  • 17,129 Answers
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Posted on Jan 21, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
  • 132 Answers
SOURCE: wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Posted on Jul 05, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
May 19, 2015 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
We have a Kenmore 70 series model 110 26722693 top loading washer... The punch tab for the relay switch has broken off so that it doesn't go into spin mode because the machine thinks the lis is...
You will need this part# Lid switchNumber:3949238which can be ordered at www.searspartsdirect.com If you have your owners manual w/parts diagram this procedure will be easy. If not, go to www.searspartsdirect.com and search by your model # be sure to include the 110. This is a very easy repair to do. I will walk this thru whilst referencing the items on the parts section. You will need some room to work behind your machine so, shut off the water to the machine, Unplug it from the outlet, and remove the water supply hoses from the back of the machine. You may want to have a pail or bucket handy to catch the water as it drains from the hoses. Move your machine away from the wall to a position that you can comfortably get access to both the front and back of the machine. Find the section called "Control panel" in your illustrated parts. 1) you will need to remove the plastic end covers on either side of the control panel Item #11. They just snap on and off. 2) With the plastic end covers off you will see a screw that looks like it holds part #7 to the machine top. Remove that screw from both sides of the control panel. Make sure that you put the screws where they will not be lost. 3) Grip both sides of the control panel from the front of the machine, and pull towards you. You should feel and hear a click. Now the control panel unit is loose from the machine. You can roll it backwards and off of the top. It can be lifted off of the top but it will still be connected via the wiring harness. Now go to the section listed as "Top and cabinet" 4) Note part #6, lift up on the tab on each one and remove them. They are going to be tight so you will need to use some force to pop them out. Once both of these have been removed the back should be released from the washer. 5) Allow the rear panel to fall back slightly then lift it off the machine. Take note how it slides in for future reference when putting it back on. 6) Now you should be able to see the hex screws #23 that hold the machine top #2 to the body wrap #5. The screws are hex and flat combi-screws, usually 1/4" or 5/16th, so a socket will fit them. Remove both of the #23 screws. 7) lift the top enough that you can gain access to the lid switch. The lid switch is usually snapped into position but you will need to remove the grounding wire screw #23 at the lid switch also. 8) Carefully unplug the lid switch harness and remove the old lid switch from the top. 9) Snap the new lid switch into place, plug in the harness plug, and secure the ground wire with the screw. 10) Line up your top for the screws #23 and re-attach the top to the wrap. 11) Carefully replace the machine rear panel. Make sure it is properly seated at the bottom and flush against the wrap. 12) Now take each #6 spring clip and re-insert it and snap it back in place This should lock the back panel in place. 13) Line up the control panel to the top and push towards the back of the machine until it clicks into place. 14) Secure the control panel with the two screws #6 and snap the end covers #11 back into place. Reconnect your water supply lines to the machine, and plug it back in. And perform a function test. If you did everything correctly, your machine will now operate in the spin cycle.
I hope this helps
May 27, 2011 | Kenmore Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Jun 10, 2009 | Maytag MAV4755A Top Load Washer
LG WF-T1022TP Fuzzy Logic
hi my name is joyce
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
joyce
Feb 06, 2009 | LG WFT1071TP Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Samsung fuzzy wasing machine WA75N6
sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Aug 07, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
