How to refresh memory of FO A650 sharp fax machine
  • 2072 Answers
SOURCE: Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Posted on Jan 10, 2008
checkitright
  • 1362 Answers
SOURCE: UX B700 Sharp Fax machine send fax issue
here is the manual
http://www.sharpusa.com/files/fax_man_UX_B700.pdf
good luck
Posted on Dec 18, 2007
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
  • 125 Answers
SOURCE: Sharp FO 4400 full memory after power surge
Try holding down the stop and start keys while turning the power on and see if that clears the problem.
Andrew
Posted on Mar 16, 2009
  • 48 Answers
SOURCE: sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Posted on May 25, 2009
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Memory full on a sharp FO-2081
Enter simulation mode using # * c * and then run test command
66-10 to clear image memory. This happends if you get a garbled fax from interference or noise. You should get a power filter with fax and network ports if it keeps happening.
Apr 03, 2014 | Sharp FO-2081 Copier
Fo-2081
I am a tech that Services Sharp. Enter simulation mode using # * c * after you are in run test command 66-10 This problem happens from you getting a bad fax mostly from noise or interference to the line. if it happens a lot to you then try getting a power filter with network and fax ports.
Dec 13, 2013 | Sharp FO-2081 Copier
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Andrew
Mar 16, 2009 | Sharp FO-4400 Fax
Sharp fax model fo 2950m
Jan 28, 2009 | Sharp FO 2950M Plain Paper Laser Fax
Open Questions:
88 people viewed this question
k24674
